06-13-2018 11:48 - last edited on 09-10-2019 14:53 by MatthewFitbit
Hi everyone! It has come to our attention that some users are experiencing issues with syncing/setting up Aria scales with Comcast/Xfinity routers and we are currently reviewing.
There is a workaround that has helped most users. For this, follow the instructions below:
Thank you all for your patience. Any update available, I'll make sure to share it in this thread.
04-04-2018 09:11
04-04-2018 09:11
04-04-2018 09:35
04-04-2018 09:35
I should have come here 2 days ago to check the forum!
My Aria also stopped syncing out of the blue on March 31st. Nothing at all had changed...it just stopped. I originally had gone through all the steps to get the scale to work when Xfinity sent us a new Gateway modem/router in January, but I double-checked to make sure everything was still set up correctly, and it was.
Frustrating!!
04-04-2018 09:37
04-04-2018 09:37
04-04-2018 09:38
04-04-2018 09:38
Same syncing issue. Same timeline. Last recorded weight was 3/15. I tried following the setup to connect (before finding this thread) and the issue remains.
04-04-2018 09:43
04-04-2018 09:43
Thanks to those of you who have contacted customer service on everyone's behalf. I sure hope that they can figure something out.
In the process of troubleshooting, I ended up "deleting" the Aria from my mobile and laptop accounts, so I can no longer see it and thus can't tell what version of firmware it had. I just wonder if something went wrong with an update...
04-04-2018 12:43 - edited 04-04-2018 12:44
Hi everyone- we are currently looking into reports on people being unable to sync on their Aria scale. We have seen a specific increase with Comcast users. Some have reported the workaround in this post has worked. If you are still not syncing can you share the make and model of your router so we can pass this on to the team? Thanks very much for your reports.
Actively managing your weight? Find accountability buddies on the Manage Weight board
04-04-2018 13:01
04-04-2018 13:01
Kate,
thank you for reaching out and becoming actively engaged in working to resolve this issue. I think if you trace back in the post you will find that the suggested workaround had worked previously however recent attempts to use it have not had any impact and the units are still not able to synch. My Internet provider is Comcast and the router that I have is a Cisco DPC3941T. Just to further clarify there are posts from people that have different Internet Providers so this is not unique to Comcast.
Thanks.
04-04-2018 13:35
04-04-2018 13:35
Kate,
Hello and thank you for responding.
I do not have Comcast and all of my other WiFi and Bluetooth enabled products in my house synch without difficulty. In addition to my Aria scale not syncing, I am unable to add additional users to the scale; I'm guessing this is due to the syncing issue. I have followed the suggestions posted by others without success.
Thank you,
Andrea
04-04-2018 14:31
04-04-2018 14:31
I have found a solution that works, although is NOT ideal. After making all the suggested changes (most of which worked for a BRIEF while, and then no longer did) the only way I was able to get my scale to sync was to connect it to my MOBILE HOTSPOT, and not my home wifi network. I have to turn the hotspot on, weigh, then turn it off again, which is a nuisance, but it has worked CONSISTENTLY for 48 hours now.
It's a pain, but will at least get me by until the real issue is fixed.
04-04-2018 17:42
04-04-2018 17:42
@KateFitbitwrote:Hi everyone- we are currently looking into reports on people being unable to sync on their Aria scale. We have seen a specific increase with Comcast users. Some have reported the workaround in this post has worked. If you are still not syncing can you share the make and model of your router so we can pass this on to the team? Thanks very much for your reports.
This worked for my scale! The summary of what happens (and I may have the technology jargon wrong.)
The scale uses b protocol (which is old technology). When your internet provider pushes an update, even though it says that the b protocol is enabled, it's not and it hangs up for devices that use "b", the scale. So, you have to re-enable it. The way to re-enable it is un-sync the (supposedly) b/g/n, by setting the router to g/n, and let it take. Then you go back and sync to b/g/n. It didn't work the first time but it did the second time. Follow the instructions ( and read the posts) to this message from KateFitBit. Good Luck! Nery
04-04-2018 18:51
04-04-2018 18:51
04-04-2018 21:05
04-04-2018 21:05
Still didn't work for my comcast router. Ive tried this so called solution so many times, Im about to throw out the scale. I used to love the fitbit products. I used to use the fitbit tracker as well. Terrible customer service (basically saying it's my fault my tracker kept breaking.) I moved on and got an apple watch (LOVE IT). Now this with the Aria? I will be moving on from this as well. Very sad & old technology Fitbit.
04-04-2018 23:43
04-04-2018 23:43
04-05-2018 07:43 - last edited on 04-06-2021 06:02 by JuanJoFitbit
hi, thanks for the info, but my router was set to the b setting. I even changed it off of b, saved it and put it back on. No special characters in the passwords either or band name.
I tried that several times and no luck.
I got a new scale too. I got the Weight Guru scale and I love it. It is Bluetooth and not wifi.
I have Comcast and a technicolor Device Type: xb3 Model DPC3941T
Moderator edit: merged replies
04-05-2018 10:03
04-05-2018 10:03
All right - I actually got my scale to work again! This is what I did:
I followed the directions in the other post about changing my Xfinity Wireless Gateway router settings for the 2.4GHz to g/n, saving, and then changing back to b/g/n and saving again. Keep in mind that I actually did this exact same process yesterday with no luck.
Then, since I had deleted myself/my personal info off of the Aria earlier (which removed it from my account), I again tried setting up the scale as a new device via my mobile app. The one thing that I did differently was to change the name of the scale. Before, I had named the scale "Aria", and that's what I was trying to name it the past couple of days. Today, I named it "NewAria". I have absolutely no clue if this is what made it work today, but I'm not going to question it!
04-05-2018 10:08
04-05-2018 10:08
short-lived fix...... not working today anymore.
04-05-2018 10:14
04-05-2018 10:14
04-05-2018 10:55 - last edited on 04-06-2021 06:05 by JuanJoFitbit
I am glad it worked for you. I did notice that I got a Fitbit update on my phone last night. I haven't tried to connect my Aria because I already got a new scale.
My aria has always been named PITA. It was hard to set it up the initial time to.
Moderator edit: merged reply
04-05-2018 12:10
04-05-2018 12:20
04-05-2018 12:20
Have tried renaming the Aria(Doorstop), still stuck in Setup Active mode...sigh
