09-16-2014 12:27 - last edited on 09-10-2019 14:53 by MatthewFitbit
The simplest and quickest approach to setting up your Aria scale is by installing and running the setup software from here.
If you are unable to complete the setup with this software, we recommend using the web-based setup as a secondary alternative. Complete instructions for this process can be found in this help article, along with the instructional video below.
Setting up your Aria via the Web-based Method
For assistance with putting your Aria in "Setup Active" mode, please consult this post.
If you are unable to complete the setup process using the above information, check this help article for more setup tips. For further assistance, please contact our Support Team at http://contact.fitbit.com or join the discussion in our Aria Community forum. Be sure to provide as many details as possible about where in the process you are getting stuck and what error you are encountering.
02-02-2018 08:22 - edited 02-02-2018 08:23
I know you did not. It was a very rude person...who is on here to troll people. Sorry for any confusion. 🙂
02-02-2018 08:24
02-02-2018 08:24
Wow, you were completely unhelpful. You did not answer my question. I had another aria at my house and it worked before. It is connected, I am talking about adding additional users to the device. Please help people in the future.
03-06-2018 06:46
03-06-2018 06:46
I set my Router to "B" only for setup, and that seemed to work. Once connected, I switched the router back to auto, and the scale still connects fine.
03-28-2018 09:08
03-28-2018 09:08
This helped! Thank you. We moved homes and my Wifi changed.
04-18-2018 04:54
04-18-2018 04:54
My Scales are really just a big lump of useless plastic.
Stopped connecting to Wifi in February.
Tried to reconnect. Have tried 2 routers.
Goes into SetUp mode. Eventually connects to the Aria Wifi, then after proceeding, half the time the web page crashes. The other quarter it gets to the wifi signal screen and half of that time it might see a number of wifi signals (the other, nothing at all).
Tells me its found the Wifi 1 in 4 times, and then "Wifi Err" - reboots straight back to the Set-Up screen.
Useless device - just useless.
04-20-2018 05:06
04-20-2018 05:06
I was setting up my fitbit Aria and got to the step where i got the scale connected to the internet and when i went to switch my phone back to my home internet from the scale network, the page went down and when i refreshed it took me back to the home page not where i was in the set up. Now the scale is flashing set up activate but when i attempt to restart the setup i can no longer connect to the scales network. How can i fix this?
04-20-2018 09:08
04-20-2018 09:08
04-20-2018 09:38
04-20-2018 09:38
05-04-2018 18:57
05-04-2018 18:57
OH MY GOD THIS WORKED. My Xfinity router was set to not accept 802.11b devices and I followed Matthews instructions - the only part I had to figure out is that if you have xfinity the login for the 10.0.0.1 page is ADMIN and password is "password" its not your usual login. From there Matthews directions are perfect.
05-09-2018 12:38
05-09-2018 12:38
Biggest issue was getting the battery cover back on before the display went dark... lol.
First try I got WIFI ERR Waited a few minutes and tried again.... Success!
Thanks!
06-05-2018 14:12
06-05-2018 14:12
PLEASE NOTE - If you are trying to setup and Aria 2 scale The process is entirely different.
Please go to the Aria 2 community for that information.
06-05-2018 20:46
06-05-2018 20:46
01-03-2019 13:30
01-03-2019 13:30
I can't even select B on my router options. It is bizarre!
01-08-2019 22:56
01-08-2019 22:56
I’m beyond frustrated. I’ve had my Aria for a while now and it used to work like a charm until the Aria 2 came out. Now, I can’t remove my device. I can’t change the Wifi network. I get all the way through the setup process and it it resets back to try again. I’ve purchased every Fitbit device and loved every single one including the Aria but there was no reason to purchase a new scale when I had a brand new one. I hate to post negative things but I’ve spent hours trying to get this scale to set change WiFi networks and I’m over it. What good is a product if you can’t use it? Trash can it goes 😞.
