09-16-2014 12:27 - last edited on 09-10-2019 14:53 by MatthewFitbit
The simplest and quickest approach to setting up your Aria scale is by installing and running the setup software from here.
If you are unable to complete the setup with this software, we recommend using the web-based setup as a secondary alternative. Complete instructions for this process can be found in this help article, along with the instructional video below.
Setting up your Aria via the Web-based Method
For assistance with putting your Aria in "Setup Active" mode, please consult this post.
If you are unable to complete the setup process using the above information, check this help article for more setup tips. For further assistance, please contact our Support Team at http://contact.fitbit.com or join the discussion in our Aria Community forum. Be sure to provide as many details as possible about where in the process you are getting stuck and what error you are encountering.
05-03-2015 12:07
05-03-2015 12:07
Hi Matthew - Thank you for your input. The scale, lapop, phone and router were next to each other for the 2+ hours I tried set up the Aria. I know the steps by heart because I did them so many times. Chrome is
05-03-2015 12:14
05-03-2015 12:14
@rrlangjr It sounds like you're referring to the fact that Aria utilizes the 802.11b standard to make its connection. This is defined by hardware, and not something that can be "fixed" without completely redesigning the scale. I understand that the most appealing scenario would be a change on Fitbit's side of things that magically allowed the Aria to work with your current network settings, but that isn't currently possible.
That being said, you are not alone in providing this feedback, and I will continue to let our team know that customers like you are interested in seeing this sort of update. You might vote or comment on this related feature Suggestion, which is the appropriate thread for that discussion.
@sandypdot It sounds like you've spent quite a bit of time working on this, and I'm really very sorry that it hasn't yet been successful. Setting up a Fitbit tracker is comparatively simple, since it's just using Bluetooth to "talk" with your computer or phone. Aria setup, on the other hand, involves using your mobile device to "introduce" Aria to the wireless router, so that they can communicate directly, without a computer being involved. That means that the process will vary depending on your unique wireless setup.
I'm hearing you say that it wasn't able to connect - does that mean you made it completely through the setup process and had it fail at the very end? If so, do you know what error message appeared on the scale's display? Knowing that bit of information is helpful in troubleshooting. I know you've spent a lot of time already, and I certainly understand if you feel like you're done trying. If you'd like to continue working on it, I'll be happy to assist.
05-03-2015 14:01
05-03-2015 14:01
05-03-2015 14:03
05-03-2015 14:03
05-03-2015 16:03
05-03-2015 16:03
@Julia_G While a wifi-hotspot can work for setting up your Aria, that definitely adds another layer of complexity to the process. We haven't done extensive testing on hotspots, but depending on the service carrier and plan configuration, it may not be possible to get your Aria connected that way. If you have a router available, that would definitely be the easier option. The error you mentioned usually indicates either a password mismatch, or a configuration issue. You might need to talk with your plan provider to make sure your device has the 802.11b standard enabled.
If you decide to go with a Withings scale instead, you can still connect that device to your Fitbit account.
05-03-2015 18:14
05-03-2015 18:14
As a frustrated consumer of the Aria scale myself, I completely understand some of these comments. I am a highly trained technical IT consultant and even I suffered for hours trying to setup the Aria scale. It is the most horrendous device I have ever used. And there is clear room for improvement so the process is less painful to consumers (without needing to change the product).
That said (@everyone else), Matthew's comment about trying to help and troubleshoot a problem is completely accurate. Without a clear understanding of what is going wrong (e.g steps in the process, errors etc) he is unable to help. Sadly too many consumers end up hear to vent because the product setup is difficult and the instructions don't make it easier.
Matthew is trying to assist. @sandypdot If you provide the information he needs, I'm sure he can help solve the problem.
@rrlangjrI was also extremely frustrated by the process of the setup and truly Fitbit should have done more (and still should do more) to make the process clearer and easier. But it can be done and you don't need to open your wireless network.
Unfortunately, as Matthew mentioned, Fitbit used an old 802.11b wireless chip in the device, and it was obviously to save costs. But it probably backfired on them somewhat. Unfortunately this can't be changed without an upgrade to the hardware, which essentially means developing a new Aria scale. It can't be fixed through a software change.
My recomendation for everyone is to run the setup process on your smartphone or tablet (iphone, Android, Windows) using this guide:
This was the easiest method and the only one that worked for me.
Note: You MUST HAVE the 802.11b protocol enabled on your wireless router that the scales will connect to before running the setup process. If you don't know how to enable 802.11b, contact the manufacturer of your wireless router for help. It should only be a two minute job to enable 802.11b once you know how.
05-03-2015 18:41
05-03-2015 18:41
05-04-2015 13:28
05-04-2015 13:28
05-05-2015 07:08
05-05-2015 07:08
I do have a combination Comcast WiFi/Internet router, but it is not the model mentioned. It is Model#TC8305C. When attempting to set up the scale, after removing the battery as instructed, the scale gives the name of our home network for WiFi. When clicking on the "I'm Connected" from the web site, it simply spins and does nothing. Starting over, the scale gives the same network name, followed by the words "Tap to change." After tapping as instructed and again activating the "I'm connected" message, it simply spins. When initially attempting to set up the scale, it read "Oops, we cannot detect a wireless network," even though the scale gives the network. I went to the alternate method using an IPhone and reinstalled the connect program with the same results. All of this was necessitated by upgrading from a Flex to a ForceHR which is now operational.
Extremely frustrating and a great deterrent to using Fitbit devices.
05-05-2015 07:12 - edited 05-09-2015 05:02
@timfmake sure you have enabled 802.11b on your Comcast router.
It will be one of the wireless protocols.
I think this will likely be your problem as I had a singular issue
initially.
Sent from my mobile, sorry for brevity, typos and abbreviated text.
05-05-2015 08:39
05-05-2015 08:39
05-05-2015 14:39
05-05-2015 14:39
05-05-2015 14:46
05-05-2015 14:46
05-05-2015 15:25
05-05-2015 15:25
05-06-2015 06:19
05-06-2015 06:19
Hi @Julia_G, thank you for your efforts in trying to fix this issue. You can get in touch with customer support any time at http://contact.fitbit.com or by calling (877) 623-4997 between the hours of 4am-8pm PST Mon-Fri and 6am-5pm PST on weekends. I'm sure they will take good care of you.
Good luck!
05-06-2015 10:14
05-06-2015 10:14
05-06-2015 10:35
05-06-2015 10:35
05-06-2015 10:37
05-06-2015 10:37
@Julia_G Thank you for the update, I'm sure customer support will reply very soon, however, I appreciate your honesty.
If you have any other questions, comments or just want to contribute in one of the Discussions boards, feel free to do so.
Have a great day!
05-06-2015 13:12
05-06-2015 13:12
05-06-2015 17:04
05-06-2015 17:04
