03-28-2017 15:48 - last edited on 04-02-2017 11:15 by FerdinandFitbit
Today I updated my Blaze. Then I noticed that the watch is now 17 minutes slower. Plz help how to set the time.
Thanks
Yang Du
Buckeye State
03-29-2017 00:55
03-29-2017 00:55
This normally sorts itself out when you next sync. Is yours still a problem?
03-29-2017 15:53
03-29-2017 15:53
Thanks for your reply. After several sync, it gradually catches up, but still 1 or 2 seconds late. I guess it's OK.
04-02-2017 11:25
04-02-2017 11:25
Hi there @Buckeye123. Good to see you in the Community Forums!
It's also great to hear that you followed @SteveH's recommendation.
In order to keep the time on your tracker right, it's not necessary for you to sync that often but syncing at least once a day and especially when your tracker comes back on after running out of battery or after being shutted down manually.
Anything else you may need, let us know!
