10-13-2017 15:56
10-13-2017 15:56
is there any way to set any of the Blaze faces to show a 24hr clock rather than just 12hr?
Best Answer10-13-2017 20:55
10-13-2017 20:55
This is set in your profile sertings at https://www.fitbit.com/user/profile/edit
You can get there by clicking the settings gear on fitbit.com
10-14-2017 17:02
10-14-2017 17:02
I'm sorry, I must be stupid, but where in settings do I find it?
The only thing I find is where to change the watch face, but no place to change to 24hrs.
10-16-2017 10:05
10-16-2017 10:05
A warm welcome to the Community @thebert666 and @Rich_Laue thanks for stopping by.
If you want to change your timezone settings, you need to do the following:
1. Log into your fitbit.com dashboard and click the gear icon in the top right corner.
2. Select “Settings” from the drop-down menu.
3. Scroll down to the Time section and choose the time zone that best reflects your current location. You can also select 12-hour or 24-hour time display format here.
4. Sync your tracker to update your time zone.
Keep in mind that you have to follow these steps from a computer, since this option is not available for phones.
Let me know the outcome. ![]()
