09-12-2016 20:22
09-12-2016 20:22
After today's update everything was working fine and then boom it wasn't. I know about the watch faces disappearing but I haven't seen this issue posted, so forgive me if it has. On my phone and CPU dashboard it shows 9 of 9 hrs for the 250 steps per hour goal but on my Blaze it only shows 8 of 9 hrs. Does anyone have a clue. I'm really close to giving up on Fitbit.
Best Answer09-12-2016 20:57
09-12-2016 20:57
@hawkyou - Hey bro, I saw @racertempo mention - "So mine sort of worked, but it only shows 1 out of 13 not my 5, I guess it did not grab the pre-update info, no big deal." Maybe this is the case with yours (just throwing that out there) Maybe tomorrow with a full day everything may sync.
09-12-2016 21:01
09-12-2016 21:01
@Brad. wrote:@hawkyou - Hey bro, I saw @racertempo mention - "So mine sort of worked, but it only shows 1 out of 13 not my 5, I guess it did not grab the pre-update info, no big deal." Maybe this is the case with yours (just throwing that out there) Maybe tomorrow with a full day everything may sync.
Never thought about that. I'm pretty sure that is it. I will check it out tomorrow. Thanks alot!
Best Answer09-12-2016 21:54
09-12-2016 21:54
Best Answer09-12-2016 22:42
09-12-2016 22:42
07:16
16:49
09-15-2016
07:16
16:49
It's great to see you around @hawkyou, @Brad., @J-flex and @mcrmama. I would like to know if you keep having problems checking your reminders to move? If you do, I recommend double checking your information by doing the following from a computer:
1. Go to Settings
2. Go to Devices
3. Go to Reminders to Move
4. Check your information
5. Edit it
6. Save
7. Sync
You can also turn off and on this feature. I hope this helps, let me know the outcome. ![]()
