02-28-2016 22:35
02-28-2016 22:35
Hi, I recently purchased a FitBit Blaze and I had a question in regards to its calendar notification feature. Is it possible for my FitBit Blaze to display notifications from my Google Calendar, rather than the Apple's integrated Calendar?
Thank you in advance.
07-16-2018 10:32
07-16-2018 10:32
While you can sync your fitbit data through the MAC, no I dont believe the calendar app will sync through the MAC .
07-17-2018 07:53
07-17-2018 07:53
The calendar can not sync with the Mac
Yes you can sync your tracker through the Mac @mrhawaii808
10-23-2018 06:21
10-23-2018 06:21
My blaze shows no notifications from iOS calendar... notifications are turned on in iPhone and blaze both. Other notifications work fine
