08-31-2021
16:11
11:20
BraulioFitbit
08-31-2021
16:11
11:20
BraulioFitbit
FitBit has removed the option to turn off All Day Sync which causes my battery to FULLY drain within 4 hours of a full charge. I cannot even use it for sleep,or walking or anything now. Everything else is turned off. PLEASE bring back abillity to turn off ALL DAY SYNC.
Moderator Edit: Formatting
Best Answer08-31-2021 16:16
08-31-2021 16:16
Hi @WineWonkette all day sync was requested and it's been implemented for quite some time now. If your Blaze battery dies too soon, have you considered logging out of the app at night to save power? You'd still get the stats in the morning. These devices do have an end of life, too. Battery dying quickly is often seen as the beginning of the end of that life.
Best Answer08-31-2021 16:31
08-31-2021 16:31
It just started with the last update. And my phone is asleep at night. Do you mean turn off the FitBit at night to save the battery? Sort of defeats the purpose of the sleep tracker.
Best Answer08-31-2021 16:37
08-31-2021 16:37
You can't turn off your Blaze. Which phone do you have? I'll move this to the proper area - iOS or Android.
Best Answer09-01-2021 04:54
09-01-2021 04:54
Hi. As of Aug 26 I have also had problems with my Blaze not holding a charge. Not sure if after 7 years it is finally kicking the bucket or an update was an issue.
Best Answer09-01-2021 07:13
09-01-2021 07:13
Hi @jostorie seven years is the longest I've seen someone use a Blaze and tell us about it on the forums. Mine lasted about two and I really missed it. Now I'm using the Luxe.
09-01-2021 11:24
09-01-2021 11:24
I know. I have been seeing so of the forums and replies and must consider myself fortunate that my Blaze has lasted this long. It definitely paid off buying it.
09-05-2021 12:00
09-05-2021 12:00
You could try turning off notifications, or the phones Bluetooth at night.
Stopping the app needs to be done through the phone settings.
09-07-2021 08:45
09-07-2021 08:45
I've been having the same issues. I'm turning off Bluetooth on my phone now when not needed to see if that helps. Very frustrating not having my sleep stats since last month as the fully charged watch is dead by morning.
