06-25-2019 15:35
06-25-2019 15:35
My dashboard will say I have active minutes and then I sync it to update my steps and the active minutes will go back to zero. It doesn’t record them anywhere. At first I thought it was just a fluke, but it’s been happening just about every day. Any suggestions as to what I should do to fix?
Best Answer06-27-2019 15:24
06-27-2019 15:24
Hi @Tgroff7, welcome to the Community forums.
Thank you for the details you've mentioned about the active minutes that are not being transferred to your account, or that are disappearing after your sync your device.
Could you please confirm if you might have logged any activity manually that could've altered your active minutes total for the day? Also, if you're using a mobile device to sync your data, make sure to check if you're getting the same information in the Fitbit app and the online dashboard.
Please keep me posted.
Best Answer06-29-2019 18:33
06-29-2019 18:33
Best Answer07-01-2019 16:48
07-01-2019 16:48
I am very responsible about recording my steps daily . Yet when the weekly analysis comes out it shows way fewer steps than I had on my Fitbit . I’d often have 15,000-17000 steps and the weekly report said my best day was 13,000 +. I find this aggravating . What to do ? J
Best Answer07-02-2019 12:15
07-02-2019 12:15
Thank you for your replies and for reporting this @Tgroff7 and @powerlift69.
Before considering other options, please make sure to restart your Blaze following these steps, then check if you continue to experience the same behavior for the following days, or the next report.
Keep me posted.
