09-11-2017
20:54
07:08
FerdinandFitbit
09-11-2017
20:54
07:08
FerdinandFitbit
On you "blaze" drag the screen over until you reach the portion that says settings.
Click on the settings.
Drag from the bottom up until a region that says something on the lines of "bluetooth" pops up.
From there click until you reach the option of "Bluetooth classics".
After that is on, go back into your bluetooth settings on your phone
The option of "Bluetooth classics" should appear.
You should be able to connect from there.
Moderator edit: Format
07:12
11:49
09-12-2017
07:12
11:49
Great to see you in the Community Forums @Dis445! 🙂
Thanks a lot for taking the time to share this with us! I'd just like to add that this would work only on Android devices as with iOS devices, the Fitbit Blaze doesn't connect through the bluetooth classic mode but just the regular bluetooth on the phone.
Hope to see you around more often.
Best Answer09-12-2017 10:39
09-12-2017 10:39
This also is only needed for music control. The sync goed throigh a different channel.
