09-15-2016 20:47
09-15-2016 20:47
Best Answer09-16-2016 02:40
09-16-2016 02:40
Hi Kushal0369
Feel free to check out the Fitbit Help Article:
URL: Click to go to the Fitbit Help Article 'My tracker's battery isn't charging'
How to clean the tracker? YouTube Video (By Craig) (For flex but similiar for other trackers)
http://www.youtube.com/watch?v=ezvXy9mKoGQ
Hope it helps
Best Answer09-16-2016 12:39
09-16-2016 12:39
If it only lasted 2 to 3 days before, something must not have been right. Try adjusting your settings so the quick view is off, the brightness is set to auto, the HR monitor is set to auto, and make sure the app is not set to all day sync nor always connected. It is likely that the screen is turning on way too often and it is too bright at night and turns on constantly in your sleep. Try adjusting the settings and see if that changes things.
If the battery doesn't last after adjusting the settings, call fitbit support as you may have a bad battery.
