07-13-2017 15:35 - edited 09-20-2017 15:59
Fitbit Update: 09/3/2017
Our team is still actively investigating the root cause of this battery drain with Blaze and the Samsung Galaxy S8/S8+. I'm sorry that many of you are still having issues with a shorter battery life, but rest assured this is being looked at as high-priority for our team. My apologies for the inconvenience, and thank you all for your patience! I will provide an update as soon as there is more information available. In the meantime, please continue manually syncing your Blaze trackers only when needed. This will help preserve the battery-life.
Fitbit Update: 08/14/2017
Hi everybody!
Thanks for reporting your experiences with a rapid battery drain on Blaze trackers and your Android device - Samsung Galaxy S8/S8+. Our team is aware this is affecting Blaze users and they are investigating the root cause. I will update this thread when there is more information available.
As a temporary workaround, turn OFF "Always Connected" and the "All-Day sync" features. Make sure to manually sync your devices at least once a day.
Thanks for your patience!
09-19-2017 13:49
09-19-2017 13:49
Correction .... 11.5 months. I'm not going to count the time it stopped working longer than a Day.
09-20-2017 08:38
09-20-2017 08:38
We need a firmware update...
09-20-2017 13:16 - edited 09-20-2017 13:24
Along with the battery drain issue are you going to fix the fact that the blaze does not sync well with an S8 and also does not receive notifications properly. I am so disappointed in fitbit. I went against my better judgment when my surge band again came unattached from the face and upgraded to the Blaze. I knew I should have just switched companies. 200 plus dollars should buy you devices that work as expected and last more than 6 months.
09-20-2017 15:55 - edited 10-16-2017 11:27
Thanks everyone for your continued patience! I can confirm that our team has thoroughly investigated this Bluetooth connection issue between Blaze and the Samsung Galaxy S8/S8+. After the investigation on our end, it looks like Samsung will need to release an update to have this resolved.
You can share your voice on the Samsung Community here and here.
I really appreciate everyone's cooperation while this was being looked into. I know this has been frustrating but thank you for your understanding. Now that we have concluded the above, I'm going to close this thread. If any new issues come up, please start a new topic.
