08-15-2017
09:30
15:53
MariamV
08-15-2017
09:30
15:53
MariamV
Hi, I am having the same problem and I have the Samsung A5, this problem started when my Blaze was last updated.
16:04
12:41
08-15-2017
16:04
12:41
@ladymart Thanks for stopping by. It's cool to have new members in the Community!
Please note that your Fitbit Blaze battery can last up to 5 days. Because battery life is affected by use and other settings, actual results may vary. Additionally, rapid battery drain can be caused for several reasons. Take a look at these tips to improve your Blaze's battery life:
Hope this helps. Keep me posted! Oh and btw, you might have noticed that I moved your post to help keep the community organized. Good luck! ![]()
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
