01-26-2018 11:33
01-26-2018 11:33
I keep trying to fully charging my Fitbit Blaze, it shows on the screen fully charged but as soon as I take it out of the charger it has only charged a quarter, the only way I can fully charge my Fitbit blaze is continually removing from the charger then clicking it back in, it is 1 month old, I have cleaned everything, I have switched off, I tried different plugs sockets, I’ve left it over night charging but still want fully charge, any help?
01-29-2018 03:04
 Community Moderator Alumni are previous members of the Moderation Team, which ensures conversations are friendly, factual, and on-topic. Moderators are here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              01-29-2018 03:04
A warm welcome to the Community @Rae672.
Thanks for troubleshooting this issue by yourself. Since the steps you tried didn't work, I recommend keeping an eye on your inbox for further assistance.
Catch you later.
 Best Answer02-01-2018 04:12
02-01-2018 04:12
Hello, I had similar trouble, I charging my device always using the power adapter( like cellphone power adapter) by wall outlet and 3 days ago my device stopped charger and Now only get charger using Computer USB port and the battery life its better than charging by wall outlet.
Hugs and cheers from Brazil
Tiago
 Best Answer03-04-2019 11:24
03-04-2019 11:24
I am having the same issue. Also tried the troubleshooting listed in the original message.
 Best Answer09-07-2019 09:55
09-07-2019 09:55
I’m having the exact same issue - has anyone found a fix?
I have to choose wether I want to record activity or sleep as my battery won’t last 24 hours 😕
 Best Answer09-07-2019 13:18
09-07-2019 13:18
Hello friend ; the unique way to fix it would be replace the battery and charge only using USB PORT FROM COMPUTER; but its very very hard ; So, when my Watch stoped, I give up and throwed in the trash . Good luck
06-11-2021 12:23
06-11-2021 12:23
I'm about to do the same and use my Apple Watch exclusively. My wife and I are done with Fitbit products, as we've gone through a few with regular use, and run into problems after a few months of ownership. The only 'help' that is offered is a discount on a different/replacement Fitbit product. The tracking is fantastic, but I'm frustrated with the continuous headaches.
