02-03-2017
21:32
14:37
DavideFitbit
02-03-2017
21:32
14:37
DavideFitbit
My fitbit blaze accidentally get wet while washing my hands. Water has got into the battery and now it doesn't work at all.
What should i do?
Best Answer02-04-2017 00:44
02-04-2017 00:44
The normal advice when a fitbit gets wet is to store it in a bag of dry rice for a couple of days to draw out any moisture and then try recharging it. It may also need a restart once it's dry and charged using this procedure:
