11-30-2017
15:51
17:09
SilviaFitbit
11-30-2017
15:51
17:09
SilviaFitbit
My Blaze battery icon has been flashing red all day, yet my app and computer show that there is a full charge.
11-30-2017 17:08
11-30-2017 17:08
Hey there @hdcole! I believe the reason why your Blaze and app aren't matching is because your Fitbit tracker isn't syncing to your Dashboard. I would like you to try this syncing procedure.
After this, you can confirm it's syncing by going to your app and below your tracker's picture you should be able to see the last time it synced. Additionally, check you're properly charging your Blaze.
Hope this helps! Keep me posted.
