09-30-2019
05:52
12:52
RicardoFitbit
09-30-2019
05:52
12:52
RicardoFitbit
where to change my fitbit blaze battery? as after 2 years of use it is not lasting a day even.
10-01-2019
12:52
07:40
10-01-2019
12:52
07:40
Hello @Dishant, welcome to the Community Forums!
I appreciate the information that was shared in your post. Let me share with you that the battery of our Blaze device was designed to last 5 days but this also depends on how frequently you use it’s features. That said, I recommend you charging your Fitbit device with a USB port from a computer or a UL-certified outlet into the wall and then turn off all the features that you don’t use that much. After doing so, please this help article for more tips and recommendations.
Such article includes as restart process that will refresh device device's performance. I'd like to let you know that it's not possible to replace the battery of your device.
Keep me posted, I’ll be right here if you need anything else.
