Battery not charging
I juz bought blaze n the battery charging logo is not showing n it is juz showing fitbit.com/setup. Anybody advise me pls...
tks
3 REPLIES 3
Hi, @Bunnio, yu will not see anything except the set up screen until it is set up, so that is quite normal.
Go ahead and give it an hour or two charge (even though you do not see the charging icon) and then set it up following the instructions at fitbit.com/setup and you should be good to go!
Welcome to the forums.
Hi @Julia_G
thanks for ur information, it really works!
Welcome to the Forums @Bunnio and @Julia_G thanks for stopping by.
I am glad to see here that the instructions provided by our friend worked and that your tracker is now paired and working properly. If you need anything else, do not hesitate in posting it.
Happy stepping! Smiley Happy
