02-09-2019
17:20
08:52
FerdinandFitbit
02-09-2019
17:20
08:52
FerdinandFitbit
I got this for Christmas and loved it for the first 4 weeks. Battery lasted so much longer than my Alta did. But then I started getting clock errors. Having to change my clock face every couple of days. Now it feeezes and is not accurate when syncing and my battery isn’t lasting a day... but the app says it still has 1/2 life. I have done a reset and still no luck.
Moderator edit: Updated title for clarity
Best Answer02-10-2019 08:51
02-10-2019 08:51
Hi there @SunsetRunner, welcome to the Fitbit Community Forums! 🙂
I'm sorry to hear that you're having problems with your Fitbit Flex not lasting as it should and the display freezing. Thanks for restarting the tracker, I'd like to help you out.
I think the best way to help you out with this is by checking the battery and if we can determine that it's faulty, our Support Team should help getting you back on track.
I can recommend putting your tracker to charge and once it's fully charged, take it off the charger and put it on. Sync it and use it as you would normally do. Make sure to sync it frequently after this (every one or two hours at least) so that the battery levels are recorded on the app logs and once the battery dies, let me know so that I can take a closer look and then we can move forward with other options to get you back on track.
I'll be looking forward for your reply.
Best Answer02-10-2019 09:05
02-10-2019 09:05
