Hey hey hey @Avoneyedoc welcome to the Community! 😄 In fact, your tracker should last longer than 2 days. Are you making sure that your Fitbit is getting fully charged? If so, is it on a USB port as recommended? If not please try those suggestions. Now, if you are following those instructions and your tracker's battery still draining, you should contact support. I know they'll be glad to assist you.
Hope this helps. Have a wonderful day! 🙂
15:21
16:29
SilviaFitbit
04-06-2016
15:21
16:29
SilviaFitbit
all day sync off still no longer than 2 days
Moderator edit: word choice
Best Answer@Avoneyedoc No. Go get it replaced.
Mine has "all-day sync", "heart rate" and other features on, 5 days between charge.
Best AnswerHi @Avoneyedoc I think the best option here is to contact support. I know they will do their best to satisfy you.
Let me know how it goes. Have a wonderful day!
@ThomasFitbit wrote:Hey hey hey @Avoneyedoc welcome to the Community! 😄 In fact, your tracker should last longer than 2 days. Are you making sure that your Fitbit is getting fully charged? If so, is it on a USB port as recommended? If not please try those suggestions. Now, if you are following those instructions and your tracker's battery still draining, you should contact support. I know they'll be glad to assist you.
@SunsetRunner I'm now into my 2nd month with the Blaze and started with about 3.5 days battery life. The last couple of weeks it is averaging 3.77 days.
Wearing it 24/7 except between 23:00 and midnight when I charge it when the low battery warning appears. HR is Auto and Quick View is on, no all day sync and Auto track set to 10 minutes.
A two weeks ago I had a "24 hour to total flat from a full charge" and realised it was what I was doing that day. A great deal of gardening, heavy overhead pruning, even to the stage where the Blaze analysed it as some Sport and mainly Aerobics. I had a sweat band over the Blaze to protect it, so I couldn't see the Quick View coming on I have turned Quick View off and gained about another day, now at 4.70 days this week with similar gardening work.
How is it goin' @Colinm39 I'm so happy to read you! 😉 Yes in fact there are several factor that would have an impact on the battery. As you said quick gesture is one of them, as well we have the alarms and all day sync. Thank you very much for sharing this with us, I hope @Avoneyedoc can read this so she can improve her Fitbit battery life.
Thank you again. Have a wonderful day! 🙂
