04-28-2016
12:47
19:47
DavideFitbit
04-28-2016
12:47
19:47
DavideFitbit
Set up Blaze today and everything works except the BP. What's wrong?
Best Answer04-28-2016 13:29
04-28-2016 13:29
What BP? I see it as Blood Pressure.
If thats the case it doesnt have that.
Wendy | CA | Moto G6 Android
Best Answer04-28-2016 13:51
04-28-2016 13:51
Best Answer04-28-2016 13:55
04-28-2016 13:55
I am by no means an expert on the Blaze but have you checked in the app to be sure the heart rate monitor is turned on? It should be set to auto by default if I rememer right. If it somehow is turned to off it would have to be turned to on or auto.
Best Answer04-28-2016 14:10
04-28-2016 14:10
04-28-2016 14:10
Have you turned it on under settings?
Click on the gear in the dashboard and go to settings. Click on your device Lefthand side and scroll down until you see it. Use the Drop down to Select Auto.
It will need to sync before it takes place.
Best Answer04-28-2016 14:23
04-28-2016 14:23
Best Answer04-28-2016 14:31
04-28-2016 14:31
Do you see the green light pulsing on the back of the Blaze? Also, are you wearing your Blaze tight enough? Make sure your wrist is clean and dry, that the back side of the Blaze is clean and dry and try again. Also, check your Fitbit app or the dashboard online to see if it is indeed recording data but not displaying it on the watch. Sometimes, it doesn't display anything on the watch if it doesn't have a good enough measurement to show at the time you request it on the device, but it does record it otherwise.
Best Answer04-28-2016 17:45
04-28-2016 17:45
Best Answer04-28-2016 17:46
04-28-2016 17:46
Best Answer04-28-2016 19:28
04-28-2016 19:28
Did you see any data being recorded on your dashboard online? If not, then you likely have a defective piece. Otherwise, for some odd reason you are unable to see the reading live on the device though it is recording the data. In which case, that may still be some defect, although probably a software issue.
Best Answer04-28-2016 22:26
04-28-2016 22:26
Please contact support someting is wrong
http://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
Best Answer04-29-2016 04:10
04-29-2016 04:10
