06-19-2016 08:03
06-19-2016 08:03
Does anyone know of a good pocket or belt clip for the Blaze. Sometimes I'd like to wear one of my regular watches but don't want to loose track of my steps.
06-27-2016 08:18
06-27-2016 08:18
I found a perfect solution. I ordered a Lighter Belt Clip on Amazon. It fits perfectly and works great clipped on to your belt. Of course the HR can't read when its in the case, but just use your phone to see step count. You can also remove the clip and just keep the case and Blaze in your pocket. There are may colors and styles to choose from and the price is under $8.00. The link below is the one I'm using
06-20-2016 05:33
06-20-2016 05:33
06-27-2016 08:18
06-27-2016 08:18
07-18-2016 13:28
07-18-2016 13:28
Below is what I did. Pulled the cord from an extra charger and added a belt clip.
07-18-2016 15:30
07-18-2016 15:30
07-18-2016 19:50
07-18-2016 19:50
@rsilva708 very inventive.
My only concern would be if you bumped up against something and the charger box opened so the Blaze would fall out of it.
07-19-2016 03:18
07-19-2016 03:18
07-19-2016 11:25
07-19-2016 11:25
@rsilva708 @jimmyg_1 I hope you're doing well! Those are very interesting ideas on how to wear the Blaze. However, I won't recommend doing that as there is a chance that the Blaze will fall. The problem is that if it gets lost like that, there won't be a replacement option!
See you around!
07-19-2016 11:51
07-19-2016 11:51
08-07-2016 16:17
08-07-2016 16:17
great ideas! Thanks. I have been resorting to pulling it out of my wrist band and placing it in my bra (on top of to breast - to avoid sweat) when pushing a stroller or shopping cart or even carrying my little one as it does not always pick up steps during these activities...
08-08-2016 10:51
08-08-2016 10:51
@jimmyg_1 Interesting! I will love to see a picture of it! Can you upload one?
@SunsetRunner Welcome to the Fitbit Community! The best thing to do when strolling is to manually log it! (Check @GisselleM's steps). That way you can get those steps that weren't tracked! I left a picture below showing how it looks!
Keep me posted!
08-08-2016 20:29
08-08-2016 20:29
08-10-2016 07:03
08-10-2016 07:03
08-17-2016 23:44
08-17-2016 23:44
the problem i have is that i like to do Fight Klub which means i wear boxing gloves - i find the movment of the gloves stops my Blaze. I really need another way of wearing it.
08-18-2016 07:28
08-18-2016 07:28
@ntmitch Welcome to the Fitbit Community! Have you tried to wear the Blaze a little bit far up your wrist? That is even recommended to get a better heart rate reading while doing intense workout. Check this post I did for more details on that. The other thing you can do is to manually log your boxing activity (check @GisselleM's post), as this option will also give you accurate data for that activity. Check the picture I left below!
@jimmyg_1 I wasn't able to see your previous post! Do you need some help?
@Angiemickey72 Thanks for the advice and for sharing it! Hopefully, that will help other users on this Community!
Hope this helps. Let me know how it goes!
12-15-2016 20:13
12-15-2016 20:13
How did you get the clip to attack to it???
12-15-2016 20:56
12-15-2016 20:56
12-18-2016 09:41
12-18-2016 09:41
Hi there @AnthonyV1279, Welcome to the Forums!
@jimmyg_1, would you mind attaching the picture using the "Photos" option at the top of the text box for the picture to show on your post and for @AnthonyV1279 to be able to see it please?
12-18-2016 16:33
12-18-2016 16:33
This is the cigarette lighter belt clip I use. last bought it from Amazon for under 10 dollars. I use it all the time and it counts steps correctly
12-20-2016 12:24 - edited 12-20-2016 12:25
