01-27-2017 06:03
01-27-2017 06:03
The design of the frame allows the edges to be damaged easily. If the frame had hard plastic inserts that would bring the edge of the frame even with the top of the sides it would protect the edges. If the frame were slightly higher than the top, it would protect the entire surface better.
01-29-2017 04:10
01-29-2017 04:10
It's great to see you here @CEConti. Thanks for your feedback about the design of the frame for the Blaze tracker. I recommend visiting our feature suggestions board and share your ideas.
Happy stepping.
01-29-2017 04:10
01-29-2017 04:10
Happy stepping.
