09-28-2017 13:59
09-28-2017 13:59
I have been using my new Blaze for 3 weeks. The battery, with the recommended settings being turned off (Quick View, HR, alarms, etc...), lasts maybe two days. Is this really the battery life to expect? The product nomenclature says up to 5 days. If this is the case, I may send in the blaze for refund, to Amazon, and maybe get a Charge HR to replace it.
I noticed similar threads out there, and hoping to get some feedback on the realistic battery life. I'm having issues charging too that I just noticed this morning. My original Charge HR worked really well, until the straps broke off.
09-28-2017 14:21
09-28-2017 14:21
The battery should last you 5 days at the least if you don't do much with it.
Do you sync your fitbit often? I only sync when I tell my app to. (mainly to conserve phone battery life).
Have you done a restart on your blaze? Please follow the directions below if not:
How do i turn off my fitbit device?
Please let us know how this goes and if it helped you at all.
Best Answer09-29-2017 09:53
09-29-2017 09:53
Best Answer09-29-2017 11:55
09-29-2017 11:55
My blaze battery life actually lasts for 6-7. I use the exercise tracker and 8 alarms as well as the breathing workouts and the fitstar every morning.
But one of things I do is during the first few charges, I let the battery drain fully and charge fully. I do this for all my electronic devices, especially smartphones. I find that helps the functions of devices, might just be me, but i have not had any issues since I have started doing this.
I typically don't charge the fitbit until the battery fully dies. Just a pet peeve of mine. Not sure if this is helpful for you, but it has worked for me.
Best Answer09-29-2017 12:31
09-29-2017 12:31
Best Answer09-29-2017 13:38
09-29-2017 13:38
Oh I didn't know that ... Maybe i'm lucky?
I usually don't overcharge them.
Good Luck with your situation.. let me know how it goes. If you are still having issues, I suggest contacting support for any additional steps.
