Does the Blaze have replacable batteries? If not, what is the ultimate or overall life expectancy of the batteries? I don't want to have to spend every year when the batteries stop holding a charge.
05:48
09:29
04-27-2016
05:48
09:29
Hello, @SunsetRunner! Welcome aboard. Well, battery life can vary with use, settings, and other factors. Your fully charged Blaze has a battery life of up to five days.This are some tips to take good care of your battery:
If you do all this your tracker should last for at least 2 year, I hope this helps, let me know. 🙂
Welcome to the Community @SunsetRunner. No, this tracker doesn't have replaceable battery, you need to charge it but actually, the Blaze battery life is awesome, mine lasts 7 days.
Happy stepping! ![]()
04-27-2016
05:48
09:29
04-27-2016
05:48
09:29
Thanks for the response. I have a Flex that I love, however, I don't like that it only lasted a year and a half. I now have to charge it every two days, but can't see myself replacing something every two years because the batteries can't be replace. Once they can make something with replacable batteries, I think I will come back to Fitbit. Until then, I guess I will go back to my Garmin Vivo Fit. I do like the Fitbit more, but the Garmin has been on daily for a year and a half as well, but has replacable batteries when they die out.
07:04
09:31
I don't have any problems charging. It charges just fine, but will not hold the charge for more than 2 days, sometimes less. It's OK, I am slowly giving up on it. I have to carry a charger with me or just charge it often. I will use it until it doesn't work anymore and will not be replacing it until I can find something with replaceable batteries. Thanks for your help.
04-30-2016
09:29
09:29
04-30-2016
09:29
09:29
Oh so it's loosing the battery to soon.
@SunsetRunner Well, I would recommend checking with our support team your last options, maybe they can offer a discount.
Let me know.
Best AnswerI have had my Blaze for a couple weeks now and my battery does not last more than 36 hours. Quick View is off, no alarms set, Heart Rate is on auto and no tracking of any exercises, etc. Just wearing it from the time it's done charging until it dies. Any suggestions? Or do I need to call support??
Best AnswerAria, Fitbit MobileTrack on iOS. Previous: Flex, Force, Surge, Blaze
Best AnswerAll batteries have a defined life where it will not hold much of a charge based on the number of charge/discharge cycles it has done and depending on how old your Blaze is the battery could just be at end of life.
There are replacement batteries online which are much cheaper than a new tracker but you will need to find someone with soldering skills to replace it for you since Fitbit do not have repair services
