11-27-2016 13:57
11-27-2016 13:57
Had my Blaze since Sept 14th 2016, and worked perfectly until 25th Nov 2016.... it won't sync and the battery is going from full charge to empty in 16 hours.... and I've turned off all the notifications I can... which kind of defeats the purposes of the features.....
I use this as my normal everyday tracker and watch and have been very happy with the Blaze... but now... its not performing as it should.
11-27-2016 16:53
11-27-2016 16:53
@JaneM70 That does not sound correct at all - have you tried restarting the tracker? Also, if you have, you may need to contact support as they can look at the behind the scene working of your Blaze and see if there is a problem. (And if so, may be covered under warranty, etc.)
Kelly | Oklahoma
Alta HR, Blaze, Flex 2, Charge 2, Charge, and Aria * IPhone 7+
Best Answer11-27-2016 20:05 - edited 11-27-2016 20:07
This is exactly what's happening with mine, too. I normally am able to go about 3 days on a charge at least and I'm finding just within the past few days, I'm having to charge it almost daily.
No matter what trick I've tried, it will not sync and the time is off by over 3 hours with no way to change it. I've restarted the Blaze and my phone. I've closed the app, reopened it, deleted the app and reinstalled. Everything. My phone is telling me the bluetooth is connected. I do get text notifications but it will not sync anything else. When someone calls, I can answer my phone but the Blaze continues to buzz as if I never answered it.
Can anyone help??
Best Answer12-23-2016 08:57
12-23-2016 08:57
I have had the same issue and don't know how to fix it. I've had my Blaze since April 2016 and this has happened a couple of times. My Blaze won't synch automatically or mannually and the screen is frozen on my activity statistics. I charge my battery and it is dead in 8 hours. Not sure what to do as I've rebooted my phone, Blaze, uninstalled and reinstalled the app. This has happened enough lately that I'm ready to drop Fitbit.
