04-30-2017 01:18
04-30-2017 01:18
I have had my Blaze for approximately 9 mths & the battery will not last any longer then 24hrs.
I have followed all the steps mentioned in other posts hoping to make a difference. But nothing helps.
Shop I purchased from won't do anything as I can't find the receipt.
Has anyone else experienced the same issue & had it solved?
thanks for any suggestions.
05-01-2017 05:51
05-01-2017 05:51
07-07-2017 08:47
07-07-2017 08:47
Same problem it will not turn off, the green lights will not stop, i turn it off than on and this morning it is dead again. I use to last 7 days now 1/2 days. How do you fix that one!
07-10-2017 04:06
07-10-2017 04:06
It's great to see you around @DrM951. Since the troubleshoot you tried didn't work, I recommend keeping an eye on your inbox for further instructions.
Let me know how it goes.
