02-24-2017 02:42
02-24-2017 02:42
I thought it may be useful to have a simple topic to track instances of this problem (the buzz on your wrist during a run, you look down, and there is a little mobile icon with a red line through it).
You will find that after the run or exercise, that the GPS tracking died right at the moment you got the error on the Blaze screen.
SO. Rather than discuss the problem, or possible work-around in this topic, can you perhaps just leave a reply to say "me too" and also list your mobile device?
This issue may be more common on android, but I'm not sure. I know of at least one person experiencing this on an iPhone 7, but I have a friend with an iPhone 6 who has NEVER experienced this.
So I'll go first..... I get this on every run, randomly. I use a Google Nexus 5x (android). VERY frustrated.
06-28-2017 02:03
06-28-2017 02:03
The only way to prevent it is leaving the app open. And switch off all energy saving features.
06-29-2017 08:09 - edited 06-29-2017 08:12
I'm experiencing the same issue as everyone who has posted to this forum. I start the exercise program (walk), and then while 45 minutes or so into the activity it drops off. (Back to watch mode). If you're lucky enough to feel the vibration from the device you can restart, otherwise the the tracking feature is lost. You get the steps logged, calories burned etc, but only as you can without using the exercise app. And this is with the app open in my phone. From the number of "no longer device user" tags, and no FIRM response from Fitbit, it seems another different more reliable product is in order.
06-29-2017 08:33
06-29-2017 08:33
Did you start the walk tracking on your Blaze or in the app?
06-29-2017 09:18
06-29-2017 09:18
06-29-2017 09:18
06-29-2017 09:18
06-29-2017 09:19
06-29-2017 09:19
Are there any energy saving features in your phone? If they are enabled, they may cause that disconnect after a certain time.
06-29-2017 09:26
06-29-2017 09:26
No energy saving settings being used. Considering the number of complaints thru this forum, and the different brands of smartphones being used, this, in my opinion is device based (Fitbit).
06-29-2017 10:06
06-29-2017 10:06
If your finding that your watch leaves the exercise mode, it is most likely because the buttons or screen is being tapped.
The process to go bqck to the clock requires a press of the lower right button which pauses the event. This would be followed by a press of the upper right buttun to end the event. Now a press of the left button or scroll up and tap Done on the screen.
This all sounds like a lot to happen accidently, but these button presses could be replaced by very light taps in the correct corners of the screen and tye event will be terminated.
This is why their is the suggestion for a screen lock mode on the Blaze, it is to easy to accidentally turn the exercise mode off by tapping the screen.
My suggesis to add your votes to this screen lock suggestion
06-29-2017 14:47
06-29-2017 14:47
Me too, iPhone 6. Was working fine until yesterday, now every time I try to start an exercise on my Blaze, it starts with only one red bar, then shortly it turns to a red phone with a slash through it.
I'm still within my 90 days at Costco so if this isn't resolved soon I'll be returning it and buying another brand.
06-29-2017 14:58
06-29-2017 14:58
Do you have the app open?
06-29-2017 15:07
06-29-2017 15:07
Yup. I think I may have solved it, I'm getting full green bars now. Just need to test it tonight in our run and see if it will stay connected the whole time.
06-29-2017 15:52
06-29-2017 15:52
07-09-2017 07:54
07-09-2017 07:54
Is this thread still open? I'm new to Fitbit and wouldn't have bought one if I'd known this.
Blaze, Oneplus 2
07-09-2017 09:50
07-09-2017 09:50
07-11-2017 06:23
07-11-2017 06:23
Me too. When I go for a walk it will buzz multiple times indicating that it has lost connection to my phone, which is in the same hand as my blaze is on. But when I get back home and go into the app I see that the map shows the complete GPS route I took so obviously my phone is not losing GPS connection. Also even though I take the same route every day the mileage carries. Sometimes it says o walk 2 miles and other times, like last night, it says only 1.63 miles.
07-11-2017 07:06
07-11-2017 07:06
Just completed 4 miles......Blaze disconnected from GPS at 3 mile mark. Unfortunately it didn't buzz or it was so weak I didn't feel it, so that I could reset. No other apps running on phone and phone on same side as Blaze. This device SUCKS in the biggest way. Time for a more reliable one. And throughout all of these running posts I don't see one response from the manufacturer. So, the news is going out to anyone I meet what a lame product this is and don't waste you money.
07-31-2017 06:14
07-31-2017 06:14
Me too and its so frustrating, Samsung Galaxy S6
07-31-2017 08:19
07-31-2017 08:19
Same issue just happened, just uploaded to blaze. Yesterday worked fine, this morning gps cut out about 2 minutes in. If I feel it vibrate how do you reset it to connect again? Finish session and just open it again?
07-31-2017 09:43
07-31-2017 09:43
07-31-2017 11:31
07-31-2017 11:31
I get these disconnections on my Galaxy S7 frequently, but even when the connection remains stable, I get wildly inaccurate speed and distance readings from my Blaze when I ride my bike. It gives me max. speeds in the high 50s, when I know I never achieve greater than 30 MPH. Blaze consistently gives me a distance of about 8.5 miles for my commute to work, which I know is exactly 6.5 miles. When I use Endomondo on the phone, I get accurate speeds and distances, so I know it is not the phone GPS that is inaccurate.
