02-24-2017 02:42
02-24-2017 02:42
I thought it may be useful to have a simple topic to track instances of this problem (the buzz on your wrist during a run, you look down, and there is a little mobile icon with a red line through it).
You will find that after the run or exercise, that the GPS tracking died right at the moment you got the error on the Blaze screen.
SO. Rather than discuss the problem, or possible work-around in this topic, can you perhaps just leave a reply to say "me too" and also list your mobile device?
This issue may be more common on android, but I'm not sure. I know of at least one person experiencing this on an iPhone 7, but I have a friend with an iPhone 6 who has NEVER experienced this.
So I'll go first..... I get this on every run, randomly. I use a Google Nexus 5x (android). VERY frustrated.
01-15-2019 06:22
01-15-2019 06:22
I wouldn't bother with chasing a fix for this.
When I emailed support they basically just say it's a problem with 'clouds, trees and building interfering with GPS signal'. Which is a load of tripe as it works perfectly with Strava on my phone or if I use Google Maps. The issue is down to some connectivity problem with the watch to the phone and the Fitbit App on GPS.
I have given up with it and won't be getting a fitbit again.
02-10-2019 15:22
02-10-2019 15:22
Hello!
On my first use of GPS from Blaze and cell phone everything worked fine and I did a 5km walk and almost 60 minutes.
Already the other day after 500 meters or 10 minutes approximately lost the connection with the GPS of the cell phone.
I use a Xiaomi Redmi 5 Plus and doing an analysis I discovered that the problem was in the simple fact disable the Wi-Fi from the mobile just leave the mobile data enabled.
So for my case the solution is: Whenever I go for a walk I leave the Wi-Fi ENABLED and everything works fine.
I hope it helps others who are having this problem.
06-03-2019 09:46
06-03-2019 09:46
Me too Samsung galaxy s9
06-03-2019 10:02
06-03-2019 10:02
I gave up trying to connect every day. I'll start bike mode and let Fitbit track calories, heart rate and activity, but I use Samsung Health app to track actual miles.
06-23-2019 23:02
06-23-2019 23:02
Me too onplus 3T
01-11-2020 14:39
01-11-2020 14:39
Me too. Fitbit Charge and iPhone X
01-13-2020 19:50 - last edited on 01-27-2020 14:12 by LiliyaFitbit
Hi
I was able to identify the issue with my Fitbit GPS disconnection. The
problem was related to the GPS on my phone malfunctioning. One it was fixed
the issue disappeared.
Regards
01-13-2020 20:14
01-13-2020 20:14
01-14-2020 07:25
01-14-2020 07:25
08-23-2020 03:34
08-23-2020 03:34
Me too, IPhone 6S Plus.
