09-12-2016 10:49 - edited 09-23-2016 15:17
9/23 Update:
See the new firmware thread here
9/22 Update:
For those that have the firmware update already, new clock faces have been re-enabled.
We've continued the rollout process. If you don't yet have the update, please be patient. We'll post updates about the rollout when we have more information.
9/19 Update:
Hey everyone - it seems like we're struggling to maintain civil conversation on this topic, so I'm going to go ahead and lock the thread. We'll open a new thread once the firmware update goes into wider distribution. Until then, here are answers to the questions that keep getting asked here:
When will I be able to download the latest update?
The update is on hold while our team addresses an issue found at the beginning of the release. Once their work is complete, we will start rolling it out again. We generally don't announce specific dates or timeframes, but you will see the update on your dashboard as soon as it is available. The only thing you need to do right now is wait patiently.
Why did you release the latest update to only a small percentage of users?
We've done tons of testing on this new firmware, but there can still be unexpected issues when we release it. If every Blaze customer updated at once, those surprises would affect everyone. Instead, we use an incremental release to observe and address issues on a relatively small scale. We definitely want the best experience possible for our Blaze customers, and a slow, cautious release helps accomplish that goal.
If only 5% of Blaze users have the update now, does that mean 10% will have it next week and 15% will have it the week after? Won't that take forever?
Nope! We aren't moving in 5% increments. We started the release at 5% and will increase it in much larger increments once we are confident that it's good to go. You should receive it soon.
Why haven't you communicated this information to customers?
All this information was previously posted in this thread, and also added to the lead post. Any time you find a discussion of an emerging issue or a newly-released update, make sure to check the first post for the latest information. We aim for clear, concise, transparent, and frequent communication - you should always find what you need in the lead post.
9/15 Update:
The new Blaze update is currently available only to a very small percentage of users, as we are troubleshooting some emerging issues. It will be released more widely soon. Once it is available, you will see a banner at the top of your website or mobile app dashboard. Thanks for your patience!
Hey everyone! ![]()
We're rolling out a new update for Blaze, release notes below:
This release also resolves the following issue:
Important to note: A sync is required after a manual shutdown or a battery drain in order to show the correct time on Blaze. This is especially important for your activity tracked by Blaze because you'll want to make sure it's associated with the current date and time.
The initial wave of users will receive the update starting September 12th, 2016, and will eventually be rolled out to everyone within a few days. If the update to the latest firmware version is not yet available for your Blaze, just hang tight!
09-13-2016 13:13 - edited 09-13-2016 13:14
@EyeVindicate wrote:Same thing here. Haven't recieved the update. Has it been pulled due to all the troubles people are having? Or are the servers just overloaded?
Hi @EyeVindicate - My understanding is that the firmware update is still rolling out according to the original schedule.
09-13-2016 13:17
09-13-2016 13:17
09-13-2016 13:22
09-13-2016 13:22
@Timpub I know a lot of people aren't in the US and don't want to call internationally. But if you can/ want to, it's easy enough to call fitbit support. That's what I do when I have a problem that needs to be addressed immediately. They may ask you to do some basic troubleshooting that's impossible in your current situation, but then they'll send you a new tracker.
09-13-2016 13:47
09-13-2016 13:47
Best Answer09-13-2016 14:35
09-13-2016 14:35
I've noticed a few very good questions posed in the last 12 hours, which covers the 4 pages of posts.. This makes it hard to answer or even find them.
If your looking for a post from fitbit suggest keeping an eye on the top post of this thread.
Alternatively you could flag a monitor asking them to jump in.
Best Answer09-13-2016 14:42
09-13-2016 14:42
@Rich_Laue Are you a monitor? Because I would REALLY like to know why it is that the only bug fitbit managed to fix in the months since the last update is the backlight being too dim when many people have been complaining about step accuracy - the fitbit's most important job - this whole time.
09-13-2016 15:00 - edited 09-13-2016 15:21
Hey everyone! A few answers to the questions being asked here:
09-13-2016 15:16
09-13-2016 15:16
I have the same problem and just contacted the support team. They are sending me a replacement.
Best Answer09-13-2016 16:00
09-13-2016 16:00
09-13-2016 16:01
09-13-2016 16:01
@MatthewFitbit I, and many other people, have been posting about this for MONTHS. I actually don't have a problem with undercounting anymore, because I learned to walk and run without swinging my arms. It just seems to me that a fitness tracker should be able to do its one major task at better than 70% accuracy. If it can't do that, there should be some urgency to fix the problem.
09-13-2016 16:06
09-13-2016 16:06
@Timpub Glad we were able to help, and thanks again for being understanding. We'll make sure to get any other affected users back up and running as quickly as we can.
@meresydotes Again, I'd recommend posting in a relevant topic with those concerns. This thread is about the latest firmware update.
09-13-2016 16:27
09-13-2016 16:27
Hi Everyone,
I am trying to check everyday but there is no update for my blaze. any suggestion i am in australia
Best Answer09-13-2016 16:34
09-13-2016 16:34
@Patel1885 wrote:Hi Everyone,
My suggestions:
Be patient.
Go for a walk.
Breath deeply.
The rollout is staged. That means, some people get it, then more get it, then more get it, then more get it until everyone has it. It might take a few days.
Don't stress. We're all waiting.
09-13-2016 16:34 - edited 09-13-2016 16:42
@Patel1885 Check the first post in this thread. The update is progressively rolling out, and is not based on region. No need to do anything - you will see the option to update sometime over the next week or so.
Edit: @muppetman beat me to it. Good advice above.
Best Answer09-13-2016 16:41
09-13-2016 17:28
09-13-2016 17:28
09-13-2016 17:57
09-13-2016 17:57
I just purchased my Blaze today and am trying to go through the setup process. The very first thing it did was go into the software update and as been in that mode for at least 30 minutes now. Is this normal for a first time update/setup?
Best Answer09-13-2016 18:19
09-13-2016 18:19
Best Answer09-13-2016 18:28
09-13-2016 18:28
@gandj3028 Please read the very first post in this thread. You will find they have stated that the new clock faces have been temporarily removed as they work on some issues.
09-13-2016 18:57
09-13-2016 18:57
They sent me a new tracker and it doesnt work either.
