03-27-2017 14:57 - edited 04-24-2017 09:02
Hey all,
Blaze firmware update for 17.8.401.3 is live!
CLOCK FACES: Chronograph, Multistat, Arc
New stuff:
The first time you go to the Relax screen you may be prompted once or twice to sync your tracker. To do so find the Sync Now option in the Fitbit app.
Other stuff:
FIXES AND KNOWN ISSUES
03-30-2017 11:51
03-30-2017 11:51
Have you synced several times? Per the instructions you need to sync at lest 3 times for the update to fully finish. Mine kept doing the update complete check until I had synced I think 4 times, and I haven't had it happen since.
03-30-2017 12:37
03-30-2017 12:37
My device a LG V10 has been updating your fitbit Blaze (synching) for over 3 hours now. It looks like my watch got some of the new features.. Should I reboot my phone and start again?
03-30-2017 17:54
03-30-2017 17:54
My Blaze battery life went from 4/5 days to 1/2 after the firmware update. Not happy ....
03-30-2017 18:17
03-30-2017 18:17
That's not a firmware issue that's a mechanical issue in the device.
03-30-2017 18:57
03-30-2017 18:57
THe updated Android app no longer has my sleep or heart rate icons. Also, the app Dashboard no longer displays in horizontal. Where did they go? I updated the firmware on my Blaze and then updated the app on my Android tablet. I can't believe the update intended to remove this data so something must have gone wrong?
03-30-2017 19:30
03-30-2017 19:30
The same problem here!!!!
03-31-2017 00:51
03-31-2017 00:51
I tried resetting my blaze, but I am still burning a lot more calories than I was before the update. I don't trust my blaze anymore.
Jan
03-31-2017 05:17
03-31-2017 05:17
Ordinarily, I would agree with you. My Blaze has worked beautifully until the day after the firmware upgrade. That is either one heck of a coincidence or an issue with the firmware upgrade.
03-31-2017 09:00 - edited 03-31-2017 09:03
I have been having a few issues with the update. I do have the new, however the option for bluetooth on the tracker is gone. I can no longer sync to my computer and Android tablet. Syncing still works with my iPhone.
As far as sleep cycles go, I can only see this on the ios app. The dashboard on my Android app is showing limited data - several tiles are missing and there is no option to edit as manuals suggest. My dashboard still shows the old way of sleep tracking and the Android app shows no option for sleep at all.
I have tried, deleting apps and restarting app, restarting the Blaze, disconnecting it from the app and reconnecting it...
03-31-2017 10:05
03-31-2017 10:05
I see the three new clock faces have appeared now.
03-31-2017 11:16
03-31-2017 11:16
My Blaze has updated with this new release via App Store and it's excellent but my husband has not received the update via App Store. He has been trying to contact the help line people to see why but it's so frustrating as only once has he had a reply since Monday and the advice was useless and showed a clear misunderstanding of the problem he had.
03-31-2017 11:29
03-31-2017 11:29
I like the new Multistat face and the full info it shows when tapped but the girly colour might not please all!
03-31-2017 20:41
03-31-2017 20:41
Fitbit is sending me a warranty replacement. My Blaze crapped out after the firmware update. I saw the new watch faces. I have to say I'm pretty disappointed. They should hire at least an average graphic designer or stick with black and white displays.
03-31-2017 22:16
03-31-2017 22:16
@Poo I agree. I like the Multistat as well. And love that it shows additional info when tapped. My only issue with is that it highlights that stat (e.g. steps) when you hit your goal. Makes it look tacky.
03-31-2017 22:19
03-31-2017 22:19
Love the new clock faces! Great to have some more choices! Keep 'em comingQ
One question though, on the Chronograph one, there's a play button in the bottom right, but I can't get it to do anything. Is this supposed to start something?
04-01-2017 00:56
04-01-2017 00:56
@SunsetRunner wrote:Love the new clock faces! Great to have some more choices! Keep 'em comingQ
If you hit the bottom right button it starts a chrono function on the watch. Kind of misleading that the icon can't be tapped, but I prefer it as it will avoid unwanted timers starting during your day.
04-01-2017 01:07
04-01-2017 01:07
Was wondering that myself. No official replies on any of the 90 odd posts so far. Perhaps they are replying directly.
04-01-2017 05:16
04-01-2017 05:16
Hi! Will be getting my new Blaze delivered today. I will fully charge and hopefully sync with the app which already is synced with my Charge 2. Will the new firmware update automatically install or will I get prompts? No clue how to do this....
04-01-2017 06:06
04-01-2017 06:06
Hello Andrew I've had no problems with this version however last night the sleep stages suddenly stopped working, ideas, thoughts ,questions?
04-01-2017 06:15
04-01-2017 06:15
Me too! I woke up this morning only find out mine did not display my sleep stages. Disappointed.
