09-18-2017 09:33 - edited 08-23-2018 15:35
Fitbit Update 8/23/18:
Hey, everyone! Just wanted to thank you all for your participation in this thread.
Since the majority of Blaze users have successfully updated to this firmware: 17.8.402.1. I have decided to close this topic from further comments.
If you still have not updated your firmware to17.8.402.1, check out this help article for how to update your device.
If you're experiencing any issues with your Blaze, unrelated to the firmware-up process, I invite you to start a new topic on the Community or find a related topic.
Thanks for all your feedback and contributions on this thread.
Fitbit Update: 11/2/2017
Hey, Blaze users!
I wanted to let you all know this firmware release to version: 17.8.402.1 is now out to 100% of users. Please update your trackers! Take a look at our update instructions and make sure to charge the tracker to a full battery before you begin using it again.
Fitbit Update: 10/26/2017
This firmware has now been released to 50% of all Blaze users. Please update your trackers if you see the update available to you!
Fitbit Update: 10/18/2017
We've begun to roll out new firmware for Blaze! This is a progressive rollout, and all Blaze users can expect to have it within a few weeks. We roll out releases in phases as a cautionary measure so that we can monitor performance closely and make adjustments if needed. This firmware update includes:
Click here to see our firmware release help article for more details on version 17.8.402.
Instructions for updating your tracker can be found here.
11-26-2017 18:29
11-26-2017 18:29
11-26-2017 23:25
11-26-2017 23:25
Hello,
I completed the update successfully ~1 month ago.
However, since the update, I am not able to track an exercise with connected GPS - that is, device is not able to connect to my mobile. Worked the weekend before the firmware update on the Blaze and no updates were done on the mobile (Sony Xperia Z5).
I have tried the normal options (restart fitbit, restart mobile etc) without success.
Please advise how to resolve.
Regards,
Sergio
11-27-2017 02:00
11-27-2017 02:00
Unfortunately you're not the only one with this exact issue after the update. The short story is that there is no resolution and Fitbit don't seem that interested in finding one. I went from pretty reliable connected GPS to instant dropouts and no reconnection after the update.
From what I've read it looks like maybe in making changes to the notification system to fix the battery drain issues on the S8 something might have been changed which had the unexpected side effect of ruining the connected GPS on some devices.
I've tried everything in the help articles plus more and am yet to resolve the issue. At this point it's either wait for another update to fix it or buy something else.
11-28-2017 07:25
11-28-2017 07:25
Since the update The screen is Dim to unreadable ON MAX brightness .. worse on other settings.
Seems to be working ( all be it unusable) but is flashing at times as well
Have Tried all the "fixes"( bit of an oxymoron) on the forums.
I don't know if this is just a coincidence that it failed at the same time, or it has just reached the end of the pre-programmed life of the unit. Is my fifth unit (previously 2 Flex then 2 Surge) and just the latest to fail prematurely, once out of warranty. They work well when alive, but get expensive when you throw them away around every 18 months
11-30-2017 15:26
11-30-2017 15:26
Before this update my Blaze maintained a charge for at least five days...since this update it barely lasts all day. What gives?
12-01-2017 05:11
12-01-2017 05:11
I agree, new update has RUINED my battery. I actually have to charge it every single night, where I used to only have to charge it every 4-5 days.
12-01-2017 05:15
12-01-2017 05:15
This new update RUINED my battery life!! I actually have to plug my Fitbit in every single night now or it will not make it thru the next day. I used to be able to charge it every 4-5 days. Will there be a fix for this anytime soon? I have been a loyal Fitbit user but may have to change if I have to charge every day, just not convenient. What is the point of having a tracker that tracks sleep if I can't wear it at night because I have to charge it? I won't charge it during the day as then it isn't tracking my steps.
12-01-2017 05:25
12-01-2017 05:25
Anyone who is now having a battery issue AFTER the last update that did not before. Can you tell us what kind of phone you are syncing to? And have your gone through the steps of unpairing, hard resetting, clearing the app cache, then repairing again to see if it helps?
12-01-2017 05:48
12-01-2017 05:48
12-01-2017 05:52
12-01-2017 05:52
Run through that and see if it helps. Some people have had a little success at it lasting somewhat longer. Its what FitBit will make you do anyway before they will help you. Its been documents in this thread but if you need help with finding it let me know.
12-01-2017 06:05
12-01-2017 06:05
I am using a Galaxy S7. I dm'd Fitbit on Twitter and they asked for info to review my log. They have opened a ticket for me. In the meantime I will try your suggestion.
12-12-2017 07:26
12-12-2017 07:26
Had a problem syncing my Blaze after updating to latest firmware. It seems that my watch was unpaired. I sync to an iOS 11.2. I was able to get my Blaze to reconnect by doing the following:
1. in the Blaze settings - set "Classic Bluetooth" to pair.
2. Shutdown watch.
3. Restart watch after 5-10 seconds.
4. go to Bluetooth settings on my iPhone and reconnect to Blaze.
Hope this helps. Just glad to get my watch synched up again!
12-15-2017 23:56
12-15-2017 23:56
I am using an Acer phone - Os 6.0
I have only had my Fitbit Blaze since Nov.28, 2017 it was working great.
But now I can't sync to my phone for notifications or sync my data at all. Also, I need to charge my Blaze part way through the second day??? Do I need to return my Blaze or is there a fix? I was loving it the first week.
12-16-2017 10:40
12-16-2017 10:40
12-21-2017 08:20
12-21-2017 08:20
I am using a Motorola Droid Z Play and I have since done all of your suggestions and unpaired, reset as well as cleared the cache to no avail. The battery will not make it thru the second day so I have to literally charge my Blaze every night. No use to have the sleep tracker anymore when I cannot wear it because it is charging. The Bluetooth portion of syncing my text and calls seems to also be an issue since the update.
12-21-2017 09:12
12-21-2017 09:12
Thought I'd share my latest update in this long-running farce.
There was a recent update to the FitBit app which appears to have fixed all of the connected GPS issues I had been experiencing since the firmware update. Everything now works as it did and as it should.
Whilst I'm glad this has now been rectified, what annoys me is that there was clearly an issue that FitBit knew about and worked on a fix for. But instead of acknowledging it and keeping customers/users in the loop, they just snuck it in whilst fobbing everyone off pretending all was well.
Just genuinely terrible customer communication really.
12-21-2017 10:25
12-21-2017 10:25
To make the battery last long you will most likely have to turn off notifications and quick peak. You should try that as a test to see if it last longer.
12-21-2017 10:26
12-21-2017 10:26
Thanks for the update, that new version helped me with some syncing issues, but still didn't rectify my GPS issues. Everything else is working well.
Glad this fixed your issues.
12-21-2017 10:28
12-21-2017 10:28
@Marshageib wrote:I am using a Motorola Droid Z Play and I have since done all of your suggestions and unpaired, reset as well as cleared the cache to no avail. The battery will not make it thru the second day so I have to literally charge my Blaze every night. No use to have the sleep tracker anymore when I cannot wear it because it is charging. The Bluetooth portion of syncing my text and calls seems to also be an issue since the update.
Do you have the Bluetooth Classic setting enabled or disabled?
12-21-2017 10:49
12-21-2017 10:49
