04-21-2018 12:27
04-21-2018 12:27
All of a sudden my Fitbit Blaze won’t hold a charge for more than a day, it’s been happening since Tuesday early morning . I first noticed something was not correct when the clock had the wrong time . I synced the device and the time was corrected and seemed to work okay. A day later I noticed I had a low battery so I charged it again. I wore it again did not have any gym activity and battery is very low. I tried all the troubleshooting steps, cleaned the device , shutdown the device and app . Still the device won’t hold charge I was getting 5 Days now barely a full day. Any suggestions.
Thanks
LPWL
04-21-2018 14:55
04-21-2018 14:55
Please clean the contacts
http://help.fitbit.com/articles/en_US/Help_article/My-tracker-s-battery-isn-t-charging/?q=not+chargi...
Then Do a Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
Also See this thread for charging best practices. If you are not charging it correctly you could be damaging the battery
https://community.fitbit.com/t5/Charge/Fitbit-charge-battery-problems/m-p/1323307#M53291
http://help.fitbit.com/articles/en_US/Help_article/1799
If that does not help contact support
http://help.fitbit.com/?cu=1
Wendy | CA | Moto G6 Android
04-21-2018 20:31
04-21-2018 20:31
My blaze is not charging. It's 1 year 6 months old... What do I do?
04-21-2018 20:34
04-21-2018 20:34
@SteveapDid you even read the post above???
04-21-2018 21:05
04-21-2018 21:05
I'm having the same issue. this past week, my fitbit charge rarely lasts more than a day.
The contacts are clean, and I only charge it when it's low. It started this week, previously I could go at least 3 days.
04-22-2018 00:53
04-22-2018 00:53
Yes I did. I did go through all the battery related links on the fitbit help page and the community. I also checked YouTube/google..
04-22-2018 00:55
04-22-2018 00:55
I too charge it only when the battery icon starts to flash on the main screen of the blaze. Not sure what went wrong. I tried whatever I could to get it back.. even tried resetting with whatever power was left.. now it's not responding at all 😞
04-22-2018 05:48
04-22-2018 05:48
Hi
I too am having this issue, my Fitbit Blaze will not keep battery, it could last up to 3 days and from about Thursday I noticed its not even lasting 24hours.
04-22-2018 06:09
04-22-2018 06:09
Thanks for the information. I have tried all the suggested steps mentioned in the links. I let it charge overnight I will see how long the battery last today. Thanks.
04-22-2018 06:20
04-22-2018 06:20
Strange..when did you buy your blaze?
04-22-2018 06:51
04-22-2018 06:51
I brought my Blaze directly from Fitbit when they first came out. I think its about 2 years old.
04-22-2018 09:33
04-22-2018 09:33
Is the battery holding ln?
04-22-2018 10:20
04-22-2018 10:20
I am having the same issue. I talked to fibit and did truble shooting and now it does not work at all. Talked to fitbit again they say they can give me 50% off that does not help the fact that before i did there trouble shooting I got a couple hours out if it and now nothing. Very disappointed in fitbit. Very disappointed in customer service. I don't know that i want anything to do with a company that does not stand behind there products. Especially when is a known problem.
04-22-2018 18:48
04-22-2018 18:48
I was asked by Fitbit to try turning off things which may impact the battery. The only thing I have on is Quick View. They want me to deplete the battery then contact them. Is this what you did and it killed your device?
Thanks
Lpwl
04-22-2018 19:26
04-22-2018 19:26
04-22-2018 23:57
04-22-2018 23:57
Yeah.. I guess it happens or starts to happen when your fitbit blaze is about 2 years old. I've been connecting with many users of blaze and all of us seem to have similar issues once the Blaze is close to 18 to 24 months old. I hope they atleast repair it for us.. (noticed screws on th back panel)
04-23-2018 00:00
04-23-2018 00:00
I did all the help stuff on their website etc and then that depleted the battery. I didnt call them before. I also followed their instructions to clean the charging connectors, tried a different official blaze charger and no luck. I've been using fibit since 2014, my fitbit one still works like a charm but not the blaze 😞
04-23-2018 05:45
04-23-2018 05:45
Is your device no longer usable after the battery was depleted? Fitbit support wants me to fully charge the device and turn off items that could drain battery. Then I’m suppose to use the device syncing 5 to 6 times a day and when I don’t see the charge icon contact them . But if I do that will it make by device unusable?
One person posted they followed troubleshooting.. not sure if they drained the battery but now their device is no longer unusable.
My device was brought early 2016 so it fits the timeframe pattern of having this charging issue.
04-23-2018 07:38
04-23-2018 07:38
I’m afraid to drain my battery if it means my device will be unusable. Did Fitbit offer to fix the battery?
04-23-2018 08:04
04-23-2018 08:04
Yes, my blaze did not respond once the battery drained out completely. I got it in Oct 2016. I would follow Fitbit tech support and see if it works or not. If not, and it screws up your device, check if you can get a replacement. As far as I know, it cannot be repaired.
