07-15-2018 11:13
07-15-2018 11:13
My Charge HR battery started to drain very fast approximately a week ago. A full charge lasted up to 4 hours only. At this time I also noticed the HR monitor also started to fail with either not reading or stuck at 70.
I noticed that one of the leds was not flashing but remained dimly lit. I have tried full reboots of the watch, turning the HR on/off and numerous syncing but all attempts have failed.
The watch has expired on the 2 year warranty in May and I am led to believe from the fitbit community that there are no repair centres for these.
It's a bit of a waste to just throw away a watch for what should be a straight forward repair for fitbit.
Let me know your recommendations on a way forward please if there are any.
Best Answer07-15-2018 13:29
07-15-2018 13:29
Sorry, but you have exhausted your options. Fitbit trackers are not repairable and parts are not available. Also sounds like it would cost more to repair than it is worth.
Best Answer07-16-2018 13:40
07-16-2018 13:40
@CraigD69 wrote:My Charge HR battery started to drain very fast approximately a week ago. A full charge lasted up to 4 hours only. At this time I also noticed the HR monitor also started to fail with either not reading or stuck at 70.
i had the same issue turned out to be water damage when i went swimming. if this the case the most they can do for you is offer you a 25 percent discount off another fitbit
