Blaze Heart rate not working
ANSWERED
Just simply does not work. I think mine is broken.
37 REPLIES 37
Me too.:( it is set to on and light isn't on and the sign is --❤. It was working 2 hrs ago.:(
It worked!!!Thanks SteveH
My wife & I have Blaze FitBits & after the latest update pushed on or around 27 - 28 Jan. & her heart rate monitor stopped working.  Seems to me to be an update issue.  Lights working just fine, but her heart rate doesn't display.  We've performed several restarts, changed the heart rate monitor settings multiple times, re-sync after each settings adjustment all with no positive resolution to the issue.
Anyone else have a problem after an update?
Thanks in advance for the help / feedback.
Restart worked for me.  Too bad it was after my sleep and workout, missed some good data.
Hi there @dzelag01, good to see you in the Community!
If you have tried all these things and your heart rate doesn't seem to work, I can recommend getting in touch with the Support Team for them to take a deeper look and help you out with this!
@Mr_Anderson, thanks for getting back and letting us know  that this did work for you! 🙂
Ferdin | Community Moderator, Fitbit
That worked perfectly! Thanks!
I'm very glad to hear that it helped @Birdbrain! 😄
Great to see you in the Community!
Just realized my Blaze quit providing HR also. I bought mine shortly after it came out. I'm hoping it is still under warranty. I don't think the Blaze has even been out a year? I'm going to call customer service later today. Tried to go to setting to turn on and off HR and the lights don't blink at all.
Had a very weird experience this past week.  Went from Winnipeg to the Caribbean on a cruise.  My Blaze started giving me the time for London, England and stopped giving my heart rate (no reading and no lights) two days into the cruise.  Last night, while in Toronto on the way home, the watch went back to Eastern time but the heart rate still didn't work.  I didn't have internet access until I got home so I checked things out this morning.  Apparently somehow the heart rate monitor had turned itself off and all I had to do was turn it back on.  The watch, however, will not come back to Central time so it's still on Toronto time despite my efforts to change the time zone manually.  So my advice to you is to check in Settings whether your heart rate monitor is actually still on.  I don't have a red-hot clue how mine turned off!
Followed the reset instructions and now my heart rate monitor is working again..took about 5 seconds
Mine arrived without the LED working. Very disappointed. TIme for a Garmin?
Hi @kmilford. Great to to see you in the Forums! 🙂
I'm sorry you're having problems with the LED ligths not working properly 😕
Have you already tried to restart your tracker? If not, you can easily do this by pressing the left and lower right buttons for 10-12 seconds. This will make your tracker to reboot. After that, see if the lights on the back are flashing. If that doesn't work, try changing the HR settings from the settings menu on the Blaze which should be the last screen. Turn it to off, then to on, then auto and see if this helps.
Let me know if you need more help with this!
Did you turn it on.
I restarted my fitbit blaze and now the HE green lights are working
My heart rate monitor on my blaze stopped working about 2 weeks ago according to my app but I just noticed it today. I’ve tried resetting it using the left and bottom right button and changing the heart rate in the app but nothing seems to be working. They flash when it resets but then they stop. Anyone know how to fix this problem?
Had the same issue. Tried restarting the device and nothing happened but changed the HR to on and it seems to work now.
this ended up just being a faulty device that they replaced.
That's great if the device is less than a year old but older and you are on your own second time I have had to replace the device on my own dime. Really you should make them to last and this has to be software because the green light are flashing. Looking at Garmin.
