Hi
I've tried looking around the forums but really I am struggling to find an answer.
I'm marathon training which is heavily dependent on pace running and heart rate. Though no matter the pace I'm getting a reading of 147-160 max.
The paces I've used so far vary from 6.50 brisk to 8.20 easy per mile
I'm not sure if the fact that my stride length varying over these paces has any effect after reading that it will estimate your heart rate as the fitbit struggles to calculate my pace particularly on the faster runs.
Any help is appreciated
Regards
07:32
10:37
12-20-2017
07:32
10:37
Hi there @fox566. Great to see you in the Community Forums! 🙂
If your Blaze is not giving you a correct heart rate reading, I can recommend to first restart your tracker. You can easily do this by pressing the left and lower right buttons for 10-12 seconds. This will make your tracker to reboot.
Once you've done this, keep in mind a few things when exercising to ensure that you will get the most accurate readings from it:
Hope this helps and let me know if you seem to have the same problems. Anything else, I'm here to help!
The bum on my Fitbit blaze is not working. Just shows
- - bpm
60 resting
i have rebooted, turned my blaze off and back on in settings, changed from auto to on and back to auto, connected to my mac laptop.
still not working. Can you help?
Best AnswerThanks
It appears the issue is more when i pick up into higher speeds and there isn't anything I can do about it. Frustrating but it seems to be the wrist heart rate monitoring.
Works fine for cycling
