Blaze: How to fix completely drained battery not charging.
If you've let your battery completely drain and you may get overheat warning that keeps from charging.
Solution: charge it in freezer. Will take awhile for battery to reach minimum but will keep it from overhearing while pulling so much current. Trick I learned from my old RC helicopter batteries similar lithium batteries.
2 REPLIES 2
Interesting. I will have to remember this
Community Council Member
Wendy | CA | Moto G6 Android
Don't know how delete post... Bad battery or regulator. Disregard past. Pissed. $200 is not worth bad engineering. If anyone had found replacement battery please post. Easy solder job
