02-22-2016 09:45 - last edited on 03-28-2016 07:40 by AndreaFitbit
Music Control gets a facelift with Blaze! Learn more about your power to control music below. For a more detailed look at Music Control on your Blaze, please see this help article.
Music Control:
With Blaze, you can control your music with the touch of a button! To access Music Control, simply swipe downward on your home screen. Improvements to this feature include a Bluetooth Low Energy (BTLE) connection for iOS instead of BT Classic. We've also added the ability to rewind and increase/decrease the volume of the song, in addition to fast forwarding and play/pause.
Notes:
No matter what you're rocking out to, we're sure you'll love using Music Control on Blaze!
03-25-2017 22:56
03-25-2017 22:56
@SunsetRunner wrote:Hi yes the phone is showing connected to bt classic Towards the blaze.
music app is google play and running
the blaze simply shows "connecting"
When my Blaze does this, I simply restart my phone. Fixes it everyone.
05-01-2017 11:50
05-01-2017 11:50
OM Goodness thank you so much this has absolutely made my day as I can do this too! You can't believe how happy I. The only issues is I now need to buy new Bluetooth headphones and don't want to pay an arm and leg as I gave mine away! 😔😨🙃😐😐
05-01-2017 12:57
05-01-2017 12:57
I only listen to audiobooks, bought my headphones at target for 10 dollars, they look isenticle to 25 dollar models i see elsewhere.
06-06-2017 11:18
06-06-2017 11:18
PLEASE HELP. I want to be able to use the music capability while I am in the 'exercise' and tracking my run pace, calories burned, etc.
06-06-2017 12:58 - edited 12-30-2017 22:32
Hello @JennyTeck simply hold in the top right button.
06-06-2017 16:18
06-06-2017 16:18
Thanks so much!
12-30-2017 09:41
12-30-2017 09:41
Thanks! I’ve been trying for days to figure out why it wouldn’t work lol
12-30-2017 22:33
12-30-2017 22:33
This and much more may be found in your downloadable or online user manual. Link is below as "help"
01-23-2018 00:21
01-23-2018 00:21
Im also having the same problem
01-23-2018 03:35
01-23-2018 03:35
Sorry @SuhasGupta I'm not sure what the problem is that your having.
08-28-2018 20:44
08-28-2018 20:44
I spent hours trading and researching and find this. I too turned off my Bluetooth earpiece let they music play for a few seconds then turn my earpiece back on and its now shirking fine. I'm using S7 Edge with Fitbit Blaze.
08-28-2018 20:46
08-28-2018 20:46
@Scott_STL wrote:I had the problem that my music controls wouldn't work while using bluetooth headphones. The problem was fixed after I turned off the headphones and then the music could be controlled by my blaze. The music was playing out of my phone speaker for a few seconds. Then, I turned the headphones on last and the blaze was showing my music and would control the volume in my bluetooth headphones. Problem solved! Galaxy Note 5, Skull Candy Headphones, Blaze 17.8.301.7
