Blaze Silent Alarm Vibration
Now I can't be the only one with this issue, the FitBit Blaze's vibration strength is just too weak, but they can't change that in a software update, but what they CAN do, is make it so that the Blaze will not stop vibrating until you turn it off yourself, that would be so helpful and would definitely wake people up, I'm a heavy sleeper so a 10 to 15 second vibration will not wake me up, I'm surprised FitBit hasn't thought of this sooner.
3 REPLIES 3
That would have the potential to kill off the battery pretty quickly. I would not use the alarm if I was a heavy sleeper.
I have both a Blaze and an Alta and use the Alta for sleeping when I need an alarm. Most of the time the Blaze one will wake me but not all the time. The Alta one seems stronger.
I have a few trackers, see my sig. In any class when i need an alarm i use an alarm clock.. My phone isn't loud enough to wake me.
