Blaze Sleep tracking FIX, no I'm not crazy
Trust me when I tell you that I read every post I could find regarding sleep detail not showing details. I tried every suggestion from users and Fitbit to try to fix the issue,
Buried within one post was a short line about changing clock faces to fix the issue. HUH?
I changed mine from Moment to Multistat, and sleep tracking started working again. I did one hard reset after changing. Tracking has worked for 2 days. A short test yes, but it had not worked for 12 days prior.
This is about the ;east painless thing you can try, to see it the clockface is the issue. Try one then another if you need to.
Hope this helps you with your issue.
0 REPLIES 0
