01-06-2016
07:40
11:10
EmersonFitbit
01-06-2016
07:40
11:10
EmersonFitbit
Time and time again we have asked you people to make the device Water Proof.
Why can't you get it through your thick skulls that there are water sports/activities.
Can I wear my Blaze while swimming?
Fitbit Blaze is rain, sweat, and splash proof. We recommend that you do not swim or shower while wearing Blaze.
Moderator Edit: Edited post title for clarity.
02-29-2016 09:06
02-29-2016 09:06
Yes, @AdamMSC - that, exactly!
03-01-2016 03:11
03-01-2016 03:11
Must admit, I've had another look at the Vivoactive HR and beginning to like it more, especially the fact that it has a much wider range of recognisable activities (as well as being waterproof). Trouble with Fitbit is they're a bit like Apple, suck you into their ecosystem. I've an Aria and I like the way everything links up together to the dashboard.
03-02-2016 13:23
03-02-2016 13:23
03-02-2016 18:18
03-02-2016 18:18
I wore my Surge everyday - in the shower, pool, hot tub and ocean - with no problems. Fitbit said not too so your wrist could be clean and breath after the early issues with another fitbit and it's bad causing rashes...but it was waterproof enough for pool and shower. If anyone showers with the Blaze - please let us know.
Best Answer03-02-2016 19:21
03-02-2016 19:21
i swam a few times with my charge hr and showered with it regularly. after about a year the band tore from the oled/hr module exposing the interior where you could clearly see rust on the vibration motor. so the charge hr is definitely not water proof.
03-02-2016 19:28
03-02-2016 19:28
"The Fitbit Surge™ is water resistant to 5 ATM, or 50 meters, and the Fitbit Charge™ and Fitbit Charge HR™ are water resistant to 1 ATM, or 10 meters, which means they can withstand accidental submersion but should be removed from water promptly. The devices cannot withstand the force associated with swimming strokes, so as mentioned previously do not swim with any Fitbit trackers."
https://help.fitbit.com/articles/en_US/Help_article/Can-I-swim-or-shower-with-my-tracker
not seeing any atm rating on the blaze. i'm guessing 1atm. it seems like the Surge is the way to go if you want a water proof fitbit (or at least the most water proof fitbit).
Best Answer03-02-2016 21:14
03-02-2016 21:14
Fitbit is only splash-proof. No swim-proof Fitbits.
Best Answer03-04-2016 14:40
03-04-2016 14:40
03-04-2016
14:54
06:29
HelenaFitbit
03-04-2016
14:54
06:29
HelenaFitbit
Can you tell me how you charge yours? The Blaze has to come off the strap and be placed in the charging box.
Moderator edit: Removed personal information.
Best Answer03-06-2016 04:35
03-06-2016 04:35
Best Answer03-10-2016 17:19
03-10-2016 17:19
03-11-2016 01:21
03-11-2016 01:21
03-11-2016 01:25
03-11-2016 01:25
03-11-2016 08:01
03-11-2016 08:01
Best Answer03-14-2016 08:01
03-14-2016 08:01
For anyone who keeps saying "It would cost too much" is crazy. Getting the device waterproof is not going to be that much more. The Samsung gear fit, Gear 2 are 100% waterproof and work great and are not that expensive. Also if you can't aford the price of the watch, then don't buy it.
If you are advertising your device as the FITNESS watch, it should be waterproof.
03-14-2016 10:05
03-14-2016 10:05
Best Answer03-15-2016 02:15
03-15-2016 02:15
Yes it is a little rude to say thick skulls but you have to wonder why a company that makes a fitness device cannot make it at least swim proof. There are others that have this capability and so far you have lost the market of swimmers who are mostly comprised of generally active people. You will not get me to upgrade from my basic fitbit until you can get this right.
Best Answer03-18-2016 09:10
03-18-2016 09:10
I know it says not recomended to be worn in the shower, but if I was to wear it in the shower would it be fine. I have a Blazeand my skin does not get irritated easily. I find that having to take it off everytime I shower can be quite annoying. I used to have a flex as well and I wore it in the ocean and it pools and in the shower and it was always fine. It worked great in water. I know the Blaze isn't as water resistant as the Flex, but all I want to know is if it with not brek in the shower. I mean a shower is just splashing anyway right? It's not being submerged at all.
03-18-2016 17:33
03-18-2016 17:33
No one really knows right now. It may or may not break but you gotta remember if it breaks it's your fault and Fitbit may not do anything about it as it's user error.
03-19-2016 01:21
03-19-2016 01:21
