08-15-2017 16:28
08-15-2017 16:28
I've had my Blaze for several months now and suddenly I've had the issue of my phone constantly saying "Looking" when I attempt to sync. After doing all the troubleshooting for syncing as suggested by the Fitbit support page, the only way to make my Blaze sync is through shutting it down and restarting it. I have no other Bluetooth signals that could block the Blaze's signal, the Blaze is close enough, my phone and application software is up-to-date. Help?
Best Answer08-15-2017 23:47
08-15-2017 23:47
How do you shut the blaze down? I habe the same problem. My blaze hasn't synced since Saturday. Thanks
Lori
Best Answer08-16-2017 06:14
08-16-2017 06:14
A warm welcome to the Community @sbajcar and @LoriCampbell it's great to see you around.
If your trackers are not syncing, I recommend following the instructions provided in the Having trouble syncing? post. After these steps your trackers should sync properly.
Let me know the outcome. ![]()
08-16-2017 06:19
08-16-2017 06:19
Thanks but I fixed my Blazes problem with not syncing. None of the recommendations here helped. I figured it out after a little research of my own. Thanks again.
Best Answer08-16-2017 16:26
08-16-2017 16:26
None of these worked except for the shutdown one. I was wondering if there was one that wouldn't require me to shutdown constantly.
Best Answer08-16-2017 17:54
08-16-2017 17:54
Hi,
When syncing your Blaze turn on notifications. My Blaze syncs every time now. Do not leave this feature on if you want more battery life. This will drain your battery much fast if left on.
