04-18-2016 15:48
04-18-2016 15:48
Hi,
Last night I charged my Blaze.
When I took it off charge it shows nothing on the screen.
I have tried every combination of buttons to power on and nothing happens.
When I put it back in its cradle there is nothing displayed on the screen.
Fitbit app says it is looking for the device.
Any ideas?
02-06-2017 16:49
02-06-2017 16:49
I have tried everything. It wont turn on.
02-06-2017 19:33
02-06-2017 19:33
Have you tried holding the left button and the right lower button at the same time for 10-15 secs?? That will reset your Fitbit.
02-07-2017
05:57
08:30
02-07-2017
05:57
08:30
Hi @Sunshine1973, Welcome to the Forums! 🙂
I'm sorry you've already tried everything and nothing works 😕
I'd say that at this point, you can get in touch with the guys at the Support Team for them to take a closer look and help you out with this and get you back on track.
Let me know if you need more help!
02-12-2017 10:32
02-12-2017 10:32
This worked for me too! Thanks so much. I was starting to get very frustrated!
02-13-2017
10:51
08:11
02-13-2017
10:51
08:11
03-09-2017 01:09
03-09-2017 01:09
I pressed the left and lower right button but my fitbit blaze doesn't work. Cannot sync it with my iphone.
03-09-2017
04:44
08:11
03-09-2017
04:44
08:11
Hi there @kayeemalanyaon. Good to see you in the Community Forums!
Thanks for trying to restart your tracker. Since that didn't work, what happens when you put your tracker in the Charger? Do you see the charging indicator or will it stay blank?
03-13-2017 23:41
03-13-2017 23:41
Hi. I have received a Fitbit blaze. When I originally synced it, the blaze charged. When I took it off the charger, there was nothing on the screen. I have tried the reset that you have spoken about, but it's not working. Any other ideas?
03-14-2017 00:26
03-14-2017 00:26
I have to use this reset workaround on a daily basis,and even then it dies. I used to charge every 3 days,but now it acts up several times a day. I love the blaze but frustrated.Might have to see what the competition has. 😞
03-14-2017
08:37
08:12
03-14-2017
08:37
08:12
Hi there @Beck85 @madblazeuser. Great to see you guys in the Fitbit Community!
@Beck85, besides the screen not working, are the green lights on the back working? If you put it in the charger, are you able to see anything coming on the display?
@madblazeuser, I would like to know if when you say that it dies, you mean that the battery drains completely or is it that the tracker just shuts off and when you press any button it comes back on again?
I'll be waiting for your replies!
03-30-2017 16:06
03-30-2017 16:06
Thank you to FerdinandFitbit for helping me turn it on
04-03-2017
09:22
08:12
04-03-2017
09:22
08:12
04-03-2017 14:32
04-03-2017 14:32
04-04-2017
11:06
08:12
04-04-2017
11:06
08:12
Hi @1565. Good to see you back! 🙂
Are you getting any type of error message when setting it up as a new device?
Please make sure you're following these instructions for that:
Go to the Account section at the top right corner on the Fitbit app and select the option that says "Set up a new device". Follow the on-screen instructions and once you're done, your tracker should be syncing without a problem.
If that doesn't work, you can go to your bluetooth settings on your phone itself, see the connected devices and tap on your Blaze, then hit the option that says "Forget this device" and follow the setup process again and see how it goes.
Let me know if you need more help with this!
04-04-2017 15:45
04-04-2017 15:45
I tried the reset and my blaze still won't turn on
04-05-2017 18:48
04-05-2017 18:48
04-05-2017 20:07
04-05-2017 20:07
04-05-2017 22:49 - edited 04-05-2017 22:51
Hello @1565 the reset procedure is press the home(left) button and the select(lower right) *buttons simultaneously for 12 seconds, not 10.
04-08-2017 10:41
04-08-2017 10:41
@FerdinandFitbit wrote:Hey there @scott890. Good to see you in the Fitbit Community!
I would recommend trying to restart the tracker once again but this time making sure you're doing it by pressing the left and lower right buttons for about 10-15 seconds. This will turn the tracker off, turn it back on by showing the Fitbit logo and this is basically a restart. If your tracker doesn't respond to this a all and nothing shows on the screen, please reach out to our Support Team who will be happy to take a deeper look and have you all set as soon as possible. Just be sure to let them know what you have done for them to move forward to a quicker resolution.
Hope to se you back on track soon and anything else you may need, I'm always around, just let me know! 🙂
So this method worked to get my fitbit back on! Thank you. Just wondering what the issue was? It helps to understand why my blaze did that to begin with
04-11-2017
11:42
08:12
04-11-2017
11:42
08:12
Hey there @JClouser. I'm excited to see you in the Forums and I'm also glad to hear that this got you back on track! 😄
There are several factors that could cause this so it would be hard to tell the exact reason. The good thing is that your tracker seems to be working again!
If you ever need further assistance, let me know, I'll be happy to help! 🙂
