04-18-2016 15:48
04-18-2016 15:48
Hi,
Last night I charged my Blaze.
When I took it off charge it shows nothing on the screen.
I have tried every combination of buttons to power on and nothing happens.
When I put it back in its cradle there is nothing displayed on the screen.
Fitbit app says it is looking for the device.
Any ideas?
09-06-2017 19:48
09-06-2017 19:48
It didn't work
09-07-2017 05:56
09-07-2017 05:56
09-07-2017 17:44
09-07-2017 17:44
I had the same problem that my blaze wouldn't turn on so I held all the buttons and the. It turned on. Try that if I doesn't work I'm sorry.
09-13-2017 11:31
09-13-2017 11:31
Thank you!! Mines back on now!!
Very happy!!
09-29-2017 12:28
09-29-2017 12:28
Blaze won’t power up
10-02-2017 09:40
10-02-2017 09:40
I tried that and it still won't work
10-02-2017 14:47
10-02-2017 14:47
Make sure it’s charged and keep trying.
10-03-2017 22:43
10-03-2017 22:43
Tried several times nothing.....when i was about to sent request to support....it came back to life.
Thanks
10-19-2017 16:34
10-19-2017 16:34
Restart worked! Thanks
10-22-2017 13:12
10-22-2017 13:12
Thank you it worked!!
11-01-2017 14:48
11-01-2017 14:48
Thank you for this information
12-09-2017 09:48
12-09-2017 09:48
The logo is up on the screen and it blinks sometimes. I'm at half-charge but I can't get it to turn on. Have held down the left and bottom right button. Have tried everything. It's been dormant for a year. So, I'm worried there's a software incompatibility issue.
12-09-2017 10:05
12-09-2017 10:05
Having the logo up @debatvenus. Then the blaze is on. Let's try opening. He Fitbit app. Logging in. And doing an add device. Replacing your current Blaze.
12-09-2017 12:50
12-09-2017 12:50
12-09-2017 12:53
12-09-2017 12:53
So is your Fitbit working now
12-09-2017 12:57
12-09-2017 12:57
12-09-2017 17:25
12-09-2017 17:25
I would suggest restarting the tracker and the phone, then try again.
12-09-2017 17:49
12-09-2017 17:49
12-09-2017 20:08 - edited 04-29-2018 13:09
@debatvenus have you followed the link posted above? Simply hold in the left and lower right buttons to restart.
If you want to turn it off you'll first have to set it up first.
12-10-2017 05:42
12-10-2017 05:42
Hi,
I just buy my Blaze, I already charge it full, but I do not know why it won't turn on at all.
When it is in charge, it is turn on, I can see the watch, but when I remove it, it just blank.
I already try push a turn on button so many time, but it is not working.
Please help.
Thanks before
