04-18-2016 15:48
04-18-2016 15:48
Hi,
Last night I charged my Blaze.
When I took it off charge it shows nothing on the screen.
I have tried every combination of buttons to power on and nothing happens.
When I put it back in its cradle there is nothing displayed on the screen.
Fitbit app says it is looking for the device.
Any ideas?
02-08-2018 01:01
02-08-2018 01:01
Hi FerdinandFitbit,
Would it be possible to paste the text of what support has done for the others.
Might save time for support and people if they can google it, rather than raise another ticket for the same issue.
Cheers
Best Answer02-11-2018 14:03
02-11-2018 14:03
My Fitbit blaze will not turn on. I have tried using the left and lower right buttons to restart it but without success. My original problem was when I tried to charge it the screen was the Fitbit logo. I do not know if it charged or not.
Best Answer02-11-2018 15:34
02-11-2018 15:34
I suggest you ask the Fitbit support team to assist you further... good luck
Best Answer02-15-2018 02:38
02-15-2018 02:38
Best Answer02-21-2018 11:14
02-21-2018 11:14
It worked. Thank you- T
Best Answer03-01-2018 08:41
03-01-2018 08:41
Saved my hide. Worked perfectly thank you 😉👍🏻
Best Answer03-06-2018 11:34
03-06-2018 11:34
Hi it didn’t work on mine it’s only working on charge once u take it off it turn it self off and wudnt come back
Best Answer03-08-2018 09:17
03-08-2018 09:17
It worked. I was so sad when my fitbit didn't charge and the screen wouldn't light up.
Best Answer03-08-2018 13:06
03-08-2018 13:06
You folks rock! I had the same issue today when I got off the treadmill with a low battery. Wouldn't turn on even when I put it in the charger. All better now!!!
Thanks!
TK
Best Answer03-08-2018 22:29
03-08-2018 22:29
How do I turn it back on
Best Answer03-09-2018 00:29
03-09-2018 00:29
@Chrissybhoy pressing any button or placing the Blaze into its powered charger should turn the unit on. It would be turned on the same way it was turned on after purchasing.
Best Answer03-09-2018 01:33
03-09-2018 01:33
Hi,
yeah i have tried all that but it remains blank !! really missing it now
Best Answer03-10-2018 12:59
03-10-2018 12:59
Thanks saved the day that worked for us as well. Cheers
Best Answer03-10-2018 19:38
03-10-2018 19:38
Hold the left and lower right buttons down at the same time and continue to hold until you see the fitbit logo come on. All fixed!
TK
Best Answer03-11-2018 14:58
03-11-2018 14:58
Have been in touch with help desk & long story made short, Fitbit are sending me a replacement watch
Best Answer03-13-2018 12:01
03-13-2018 12:01
Mine dis the same thing. Glad it came back on. Will go home and charge it.
Best Answer03-14-2018 05:01
03-14-2018 05:01
Hello all, I hope you are doing fine.
I want to thank you all for troubleshooting this by yourselves and would like to know if you keep having issues with your trackers? Could you please tell me which troubleshoot have you tried so far? Have you tried to perform a restart? If you haven't, I recommend trying this by doing the following:
Hope to hear from you soon. ![]()
Best Answer03-18-2018 06:00
03-18-2018 06:00
Best Answer03-18-2018 06:51
03-18-2018 06:51
Best Answer03-18-2018 13:33
03-18-2018 13:33
Hiya, my problem is exactly the same as @Bock65. Though I was wearing my Fitbit while cleaning and I got a splash of water on it so I’m wondering if this has something to do with it. Left in rice all night, the LED turnt on randomly when charging then went off and hasn’t come back on again. Tried reset options, no screen just green lights and vibrating. My phone is recognising the Fitbit also and says battery dead but it’s on charge and not charging. Please help.
