01-08-2017
17:01
19:03
DavideFitbit
01-08-2017
17:01
19:03
DavideFitbit
I am having issues with my fitbit Blaze which I was given for Christmas(2 weeks ago) . We purchased the product directly from the FitBit store.
I have set up my account and synced my watch to it however the actual screen/device only works when it is docked on the charger. As soon as I take it off the charge the screen is unresponsive.
My online account recognised that the battery is full as does the screen when it is initially docked on the charger.
I have reset the device twice (while on the charger) but the screen will not activate unless it is docked.
Please help – this is extremely frustrating!
Moderator edit: format
01-09-2017 02:06
01-09-2017 02:06
Same issue here. Have been in touch again with Support and waiting for a reply. This is a recent problem for me. Initially I had a problem with the battery not lasting as long as it should which was resolved by turning off most features.... and now this....after leaving it to charge overnight, it only works when in the charger otherwise it's as dead as a doornail.
01-09-2017 02:51
01-09-2017 02:51
i am having same issue just noticed it today, went to put it on and a the screen was blank put it in charger and it lights up strange, who do we contact to fix it?
01-09-2017 04:54
01-09-2017 04:54
Support has asked for a video of the problem which I have just sent....tricky taking the Blaze out of the charger and into the wrist holder with one hand, but managed to do it. Hopefully will have an answer soon.
01-09-2017 06:03
01-09-2017 06:03
god this is frustrating, i have the same issue here. perfectly charged in the dock. however when i take it out it instant goes off. fix this problem pls fixbit
01-09-2017 14:10
01-09-2017 14:10
Sent off the video and it appears they can't fix and are looking into my warranty eligibility. I told them I purchased an extended 3 year replacement warranty through the store and showed them a copy of the receipt. This is so poor. No explanation and I won't be able to get to the store until the weekend. My Blaze is less than a year old.
01-09-2017 15:41
01-09-2017 15:41
The same thing has happened to mine. Really Frustrating
01-09-2017 22:13
01-09-2017 22:13
I have just sent them a facebook message and posted on their page (I included a video as well).
Hopefully that resolves the issue! Fingers crossed! I will let you know how I go!
03-04-2017 16:08 - edited 03-04-2017 16:15
Hi,
I have the same problem, have you solved it yet?
03-04-2017 17:27
03-04-2017 17:27
Thie problem couldn't be fixed and I returned my Blaze to the store for a replacement as it was still under warranty.
