04-26-2016 07:00
04-26-2016 07:00
Best Answer04-26-2016 07:06
04-26-2016 07:06
@SunsetRunner Yeah, I have my Blaze and blue-tooth headphones paired to my phone at the same time. No problems.
04-26-2016 07:31
04-26-2016 07:31
04-26-2016 09:17
04-26-2016 09:17
04-28-2016 06:48
04-28-2016 06:48
Hello @SunsetRunner, @Nocturnx, @Rich_Laue and @TechJunkie thanks for stopping by. 😉 When I do Zumba I use a Bluetooth speaker and the Blaze, they work great together!
my Blaze!
Happy stepping! 🙂
It is health that is real wealth and not pieces of silver and gold! Share your story!
04-28-2016 13:26
04-28-2016 13:26
@AngelaFitbit wrote:Hello @SunsetRunner, @Nocturnx, @Rich_Laue and @TechJunkie thanks for stopping by. 😉 When I do Zumba I use a Bluetooth speaker and the Blaze, they work great together!
my Blaze!
Happy stepping! 🙂
@AngelaMa the Blaze is my first FitBit. Many of my family members have the Charge or Charge HR. I would have to agree that I really like my Blaze. I am confident that FitBit will continue to tweak the firmware to fine tune the sensors and will provide some additional features and clock faces in time. I was very pleased when I found that my Blaze would control the sound level of the music when wearing my bluetooth earbuds.
04-30-2016 05:59
04-30-2016 05:59
Hello @TechJunkie I'm glad to know you are enjoying the Fitbit Blaze, in my experience is the best Fitbit tracker of all times! 🙂 Also the idea to add more clock faces for the Blaze has already been suggested in the Feature Request board vote and add your comments.
Thanks for stopping by! 🙂 ![]()
08-30-2016 00:36
08-30-2016 00:36
12-20-2016 12:47
12-20-2016 12:47
I have just today joined the Blaze family. Loving it thus far! For me it apperas that blaze has connected via bluetooth to the phone but its unable to let me control music when I have bluetooth headphones/speakers also paired with phone. Any solutions for this?
Best Answer12-20-2016 17:00
12-20-2016 17:00
I haven't noticed a problem with this yet at least not with my 2 headphones and 2 speakers.
Not knowing what phone I'll tell you what can be done on Android.. Open the Bluetooth settings - find the headphones - tap on the info icon to the right. Turn off text input. This will disable the headphones music control.
03-27-2017 04:51
03-27-2017 04:51
I have exactly the same problem. Music control works when my Bluetooth headphones are not connected but as soon as they are the Music Control screen can't connect
Best Answer06-26-2017 19:39
06-26-2017 19:39
I had this issue as well. Has anyone found a sollution?
Best Answer06-26-2017 19:45
06-26-2017 19:45
Im not sure what phone or OS you guys have. The Blaze Music nd your Headphones music control connect as input devices to your phone.
On my Android Marshmellow i simply tell the OS to not attach the headphones controls.
06-27-2017 08:05
06-27-2017 08:05
Best Answer04-22-2018 10:00
04-22-2018 10:00
thanks for this super helpful reply. What earbuds did you get and where did you get them?
Best Answer04-22-2018 10:01
04-22-2018 10:01
Thank you for the super helpful reply. What earbbuds do you use and where did you get them?
Best Answer04-22-2018 23:21 - edited 05-25-2018 18:19
@audra585 tap on the device under Bluetooth, this switches to enable or disable.
05-25-2018 14:42
05-25-2018 14:42
Hello AngelaMa so I’m just about to get my Fitbit Blaze and I was woundering if I connect my BlueTooth earbuds right to the Blaze and Play my music from there? Thanks
Sincerley, Fitbit User
Best Answer05-25-2018 18:18
05-25-2018 18:18
@Stewart2005 no headphones will not connect to the Blaze, the Blaze also does not have the ability to store music.
The Blaze replacement, the Versa and also the Ionic have storage for music and a bluetoothBspeaker/headphones will connect.
05-26-2018 05:14
05-26-2018 05:14
Ok so I can not connect it to my Blaze but I can play/stop the music I’m playing on my IPhone
