02-25-2017 09:09
02-25-2017 09:09
I've just ordered a Blaze...very excited! I already have a charge hr but the strap is looking a bit tired so I treated myself 😀 anyway for now I will not be wearing the blaze at work (let my own one get dirty etc) so should I shut it down if only really using it at weekends? Thanks.
Best Answer02-25-2017 12:23
02-25-2017 12:23
Hi, @samjue86, to save battery I usually shut down my Blaze when I am not wearing it. Remember that even turned off it will gradually lose some battery power, so it is a good idea to keep it topped up now and again. Frequent deep discharge is not good for modern lithium ion type batteries,
Switching between Blaze and Charge HR works fine in my experience. Just always remember to sync before you switch, and make sure the tracker you are putting on shows the steps from the previous tracker before you set off.
02-25-2017 12:23
