03-14-2016 16:03
03-14-2016 16:03
Best Answer03-15-2016 01:33
03-15-2016 01:33
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
Best Answer03-15-2016 03:04
03-15-2016 03:04
If ypu want to track your walk with GPS, the app needs to be running, not open.
Your post is asking two unrelated questions.
Can i sync without network? @MikeF answered this one for you.
Can i track my walk without network? You do not sync to track a walk.
The answer would be in the question, Can you turn both BT and GPS on while in airplane mode? If you can answer yes to both then i would say probably, you will need to test it out, for it is your phone and only you would be able to try this out.
Put your phone in airplane mode, turn on BT and GPS. Start up the Hike tracking. Does the Blaze find a GPS signal? Or do you get an error?
04-05-2016 16:05
04-05-2016 16:05
Best Answer04-06-2016 02:21
04-06-2016 02:21
That is correct, when you open the app, it will try and sync your fitbit, without internet it will not be able to do this. The Blaze will keep 7 days of minute detail, to sync it needs to be able to send the data to dotbit. Note the app goes out to Fitbit to display Tue data.
There is a mode, seems to happen after a sync, where the app becomes a remote display and doesn't need a network.
Best Answer04-19-2016 12:07
04-19-2016 12:07
Best Answer04-19-2016 13:51
04-19-2016 13:51
04-19-2016 13:54
04-19-2016 13:54
Best Answer04-23-2016 10:42
04-23-2016 10:42
I have turned off all network to the internet, and the Blaze still connects and records the gps.
To the best of my knowledge, and what the about connected gps party says, the Blaze recreceived and stores the GPS data from the connected GPS, all the phone speed is send the gps reasons to the Blaze.
Now even I'd the GPS data is stored on the phone, a network will still not be required. The phone doesn't need the internet roo store data on the phone.
Best Answer04-23-2017 00:47
04-23-2017 00:47
I will be experimenting with this subject today while teaching an ice arrest class on a nearby peak. Will report back with my findings.
04-23-2017 11:11
04-23-2017 11:11
I experimented quite a bit with this last summer with a Charge 2 not a Blaze and it will collect and track all the data while you're out, including GPS, and then its sync ALL the data when you get service again.
While you're out with no service it will still sync some things like steps, sleep data, and HR but it will not create "exercises" or show GPS, Altitude/Elevation while you're out. Only after you sync with a phone with call service.
Best Answer04-23-2017 11:33
04-23-2017 11:33
Without an internet vonnection, you still will be able to see live data on through the app, but this is not a sync, which does not happen unless the data can be sent to the Fitbit server.
As for airplane mode, this turns all the radios off thus breaking comunication between the phone and tracker.
As for memory on the Blaze it has a 7 day detail and an additional 23 of total steps per day.
Best Answer08-09-2017 11:51
08-09-2017 11:51
Hi Samuel,
I was wondering if you got a chance to experiment with tracking w/ the blaze while out on a peak, and if so, what you found out? I'll be going on a week long backpacking trip later this month and would be really psyched to know that the blaze might actually work out there... I usually keep my (android) cell phone in airplane mode while backpacking and am still able to use HalfMile's PCT app, so I'm assuming my GPS works while in airplane mode. Thanks!
Best Answer08-10-2017 12:44
08-10-2017 12:44
I was not able to get the blaze to record GPS data while in Airplane mode. It might be worth noting that I use a much older Samsung Note II.
Best Answer08-10-2017 12:50
08-10-2017 12:50
I have an iPhone and the gps is always running even in Airplane mode and I have the Charge 2. It will track my gps while I'm out backpacking but I can't see it until I'm back in service.
The app will still calculate steps, mileage and sleep and sync that while you're out but it syncs all the fun data when you get back to cell service.
Best Answer08-10-2017 13:06
08-10-2017 13:06
In airplane mode @Sfnewbee is bluetooth turned on? Your tracker will need access to your phones bluetooth so that it may have access to the phones GPS.
As for calculating distance, this usually happens in the tracker then durring a sync the info gets put on the fitbit server. Now the app gets its info to display from the same server.
Best Answer08-10-2017 18:44
08-10-2017 18:44
Thank you for the reply... I guess I'll just give a go and share my results later this month.
