12-25-2016 11:21
12-25-2016 11:21
Phone asked if Blaze was to keep phone auto unlocked when attached. Would like to change this so that phone remains locked - anyone know how?
12-26-2016 08:04
12-26-2016 08:04
Are you referring to using a "trusted device" with Android to unlock your phone when it is near your Blaze? If so, just turn that feature off in your phone's security settings.
12-26-2016
09:26
07:42
12-26-2016
09:26
07:42
Welcome to the Fitbit Community @Ali150! 🙂
To add to the great advice @SunsetRunner gave here, make sure to go to the settings on your phone, here go to Lock Screen and Security, then go to Secure Lock Settings, go to Smart Lock and enter your pattern, then go to trusted devices, tap on your Blaze and hit "Remove trusted device". This way, your phone will not unlock when it's in proximity with your Blaze.
Hope this helps. Let us know if you need more help!
